Rattling/clicking noise from Transfer case
OK before I dig into it, maybe someone will recognize these symptoms and have an idea for me. Lately, when I have my hubs locked and am going down the road in 2 wheel drive, I can hear a noise coming from underneath my Bronco. I assume it's from the transfer case. If I unlock the hubs it goes away so it's got to be something the front driveshaft is turning. The reason I have my hubs locked and running down the road in 2wd is that it's more convenient when going to the beach to just go ahead and lock the hubs before I leave. It has been doing it for a while but seems like it's getting worse.
Any ideas?
JD
i would check the driveshaft and ujoints
reach under there and grab that driveshaft...try to wiggle it and see if there is a lot of slack. more than likely...you might have a cap failing at either end of the shaft.
how far are you driving with 2wd and hubs locked?
Probably drive about 10 miles each way. I'll get under there tonight.
Yes Chuck, you were correct. Pulled it out last night and getting ready to rebuild.
  Adjusting Transfer Case Shifter jdowns67 1 758 10-27-2014, 01:49 PM
  t-shift t-case won't go into 4-lo scbronco 3 2,290 04-01-2014, 09:54 AM
  what transfer case Ron Burgandy 4 1,680 08-18-2013, 11:06 AM
Last Post: 1st Bronco
  90 Transfer Case Queston 2000F150SAS 0 2,032 03-28-2011, 10:17 AM
Last Post: 2000F150SAS
  STak 4x4 Monster Transfer Case josephitguy 2 1,002 01-20-2011, 12:41 PM
  Need help with transfer case install 73Bronc 34 9,266 08-18-2010, 11:45 PM
Last Post: 73Bronc
  Ford Automatic Transfer Case Wiring 2000F150SAS 0 938 09-01-2009, 07:57 AM
  Transfer Case Issues Pup 2 2,426 08-28-2009, 06:59 PM
Last Post: Pup
  90 Transfer Case Motor Question 2000F150SAS 0 818 08-03-2009, 01:05 PM
  Transmission and Transfer Cases in Ford Fullsize trucks... Mtrhd0024 8 1,993 05-11-2009, 10:38 PM
Last Post: bone collector
