10th Annual NovRun@URE '15 **The Big One Zero**TEN**
The update is the check I have been waitting on for the second part of the money to order parts finally arived today so I can order brake lines and fuel lines and clips now. Trying to go over everything I need to get it road worthy but keep feel like I am forgetting things oh yeah need to find a place to install the trans cooler and find or make lines for that as well.
Put the trans cooler under the seat and you will have heated seat. Not long til Novrun are U gonna make it?
Are you using the cooler in the radiator?
I am gonna use the cooler I got from Chuck as I have a nice Aluminum radiator I got in one of the deals I wanna use and it doesn't have a auto cooler in it. My mindset is to think I can make it but realistically unsure. I get one more check for parts but it doesn't come till the 1st of Nov so if there are last minute things I can put off till then trying to get as much done as possible might have to make a run to Duff's for parts if I think that is all I would need to finish would rather get parts else where as they would be cheaper but will make that call on the 2nd of Nov.
If you have a good fan and shroud on the radiator, you can get away with mounting the aux cooler to the front of the radiator without affecting the engine temp. You ate going to need a pretty high btu cooler if it is your only cooling source.
Can you go in further detail my current fan is the engine fan remember I havn't even thought about the plan of action with the cooler open to all ideas.
Absolutely man. Start a new thread and I will be happy to elaborate as I have had just about every cooling iteration known to man, but I don't want to muck up the NovRun thread with a bunch of tech stuff.
Hey Chuck, maybe you should bring a spare axle housing, 4 spare shafts and a complete 3rd...just in case Daniel schools your a$$ again!
You are the one to talk...
I put a new 15 inch steering wheel on today as the 13 inch I had on it was a handful since I locked the front. With all my antique parts maybe i will just spectate and watch you guys bust those hi performance parts. Nah that would be no fun.
  16th Annual CB4x4 November Run snipes243 1 5,700 07-06-2022, 06:52 PM
  15th Annual NovRun AKA 2020 RonaRun Bronco Biff 0 5,771 11-09-2020, 01:05 PM
  14th Annual NOVRN@URE!! blazinchuck 15 10,720 11-10-2019, 08:37 PM
  2018 Annual NovRun @ Uwharrie coming up November 3rd!!! The traditon lives on!! Bronco Biff 5 5,892 11-05-2018, 01:25 PM
  12th Annual NovRun@URE '17 - TWELVE!!!! chuzie 18 10,940 11-06-2017, 11:14 PM
Last Post: godevil
  2016 Annual NovRun @ Uwharrie coming up November 11th!!! Bronco Biff 148 36,625 11-20-2016, 10:04 PM
  9th Annual NOVRUN@URE '14 chuzie 172 35,876 12-31-2014, 12:17 AM
  Sorry we missed URE!!! but... scbronco 2 3,171 12-07-2014, 11:47 PM
  Final URE run/Meeting nhopman 3 3,233 12-07-2014, 02:54 PM
  URE fun run anyone??? broncosbybart 22 9,022 07-13-2014, 05:03 PM
