Transfer Cross-Over
Just wondering if a '91-'93 Explorer transfer case will fit a '90 Bronco II. Does my driveshaft have to be modified? I am already running a '91 Explorer tranny, so I was thinking that the t-case would work, but since i am not much of a ford guy (sorry 2nd one ('88 Bronco 1st one) so I don't know much about them.
Thanks for any and all help!!
yes the trans case will bolt up
and if you are using and exlporer trans then get the front driveshaft from and exlporer and it should bolt up (bw1354 uses a fixed yoke bw1350 uses a slip yoke on the front) the rear will be fine becuase both tcases use the same size flange
o yeah im guessing both tcases are push botton then it should be a pretty easy swap
  Adjusting Transfer Case Shifter jdowns67 1 1,671 10-27-2014, 01:49 PM
  8.8 Cross Pin bolt damage JayT 15 8,797 08-08-2014, 10:55 AM
  what transfer case Ron Burgandy 4 3,562 08-18-2013, 11:06 AM
Last Post: 1st Bronco
  Rattling/clicking noise from Transfer case jdowns67 3 2,715 05-15-2012, 08:03 AM
  90 Transfer Case Queston 2000F150SAS 0 2,951 03-28-2011, 10:17 AM
Last Post: 2000F150SAS
  STak 4x4 Monster Transfer Case josephitguy 2 2,327 01-20-2011, 12:41 PM
  Need help with transfer case install 73Bronc 34 16,888 08-18-2010, 11:45 PM
Last Post: 73Bronc
  Ford Automatic Transfer Case Wiring 2000F150SAS 0 1,948 09-01-2009, 07:57 AM
  Transfer Case Issues Pup 2 3,924 08-28-2009, 06:59 PM
Last Post: Pup
  90 Transfer Case Motor Question 2000F150SAS 0 1,650 08-03-2009, 01:05 PM
