power steering set up advice ??????
too many options on an early bronco. wild horses offers 3 different set ups. so far im liking the rocksteer box $774.99. but it dont come with anything else. i want bad ass steering. so what are you guys running ?
and advice or tech . let me know. thanks.
If you ever consider upgrading to an explorer serp front end the PS pump is great and you can certainly do it for less than $800 though the bronco box is what is gonna jack the price up though there are alternatives like the scout box.
i'd love to upgrade to the explorer serp. set up. might even try the mustang set up.
Question for the group. There is 79 Bronco in the area that a guy is parting out. He said it has the entire power steering system. Will it swap over to my 69 with relative ease or should I look elsewhere????
JustJeff Wrote:Question for the group. There is 79 Bronco in the area that a guy is parting out. He said it has the entire power steering system. Will it swap over to my 69 with relative ease or should I look elsewhere????
the box will fit on the frame but you have to drill another bolt hole through the frame. and then the pitman arm will be facing in the wrong direction. im not sure if you can turn the arm around or not because of the splines on the sector shaft . i bought a stock rolling chassis that im picking up tonight. it has pwr steering on it. im gonna part it out.
the box needs to be converted to a 2wd worm gear...that way it will turn the pitman arm the right way for early bronco.
Mike, why didnt you get my steering box?? its westcoast broncos rock crawler box...even tapped for hydro down the road when you want it. they also offer the bolt in bracket so you dont have to drill a new hole. Thats the system, im running on mine...:xyxthumbs:
blazinchuck Wrote:.
i forgot about that box. i'll call you.
  Heim Steering wepuckett 20 9,467 08-28-2015, 03:18 PM
  Steering box help snipes243 24 17,774 07-17-2015, 09:42 AM
  What type Power Steering Cooler are you all using? Broncitis 7 4,148 07-16-2015, 01:32 AM
  What to do advice Phoneman 5 5,586 05-14-2014, 05:56 PM
Last Post: Phoneman
  Quick disconnect steering wheel snipes243 4 5,435 08-21-2012, 06:50 PM
  Power Steering issues Crawdad 31 13,352 07-28-2011, 09:29 PM
  A little advice rancej 5 3,632 03-19-2011, 11:53 PM
Last Post: rancej
  Cam advice.... chuzie 32 18,640 02-01-2011, 07:34 PM
  Home made heavy duty steering Timstrk 4 4,192 11-25-2010, 10:47 AM
