What type Power Steering Cooler are you all using?
My power steering has been getting hot and noisy on these hot days. Not sure if I am going in the right direction but I ordered a Hayden 402 5x15 7/8ths transmission cooler to put on it. The stock little one is not getting it done.
What kind of pump are you
Using? If it is the stock Ford pump, it will make noise. The Saginaw swap is a common upgrade
X2 on the Saginaw change. You just got to remove all the air out of lines or it will throw-up all over the place. I went with a derale oil cooler and mounted on front crossmember.
It is a stock Ford pump and is quiet til the temps get above 90 or so and when it does start making noise I can let it cool for 10 or 15 minotes and it'll be quiet for a lil bit. Is the Saginaw a junk yard part or can ya get them at the parts houses?
I managed to pick my current one up from Charles. My last one I had on my 76 came from Scrapman on Classic for $120 delivered. Vendors carry them as well but are more expensive. Junk yards should have them, chk old Cadillacs and Chevy trucks. You will need to get the bracket or brackets depending on your motor, plus the fittings. Keep in mind a dual sagi pump won't fit a single sagi bracket. A dual sagi could run hydroboost in addition to your pwr steering. Charles, chuck or Chuzie can fill in the details I failed to provide.
The Tranny cooler hooked to the Power steering has fixed the problem.
good deal!...i might have a complete sag pump and hoses coming available soon. removing a fairly new unit for a explorer set up.
blazinchuck Wrote:good deal!...i might have a complete sag pump and hoses coming available soon. removing a fairly new unit for a explorer set up.
Keep me in mind for that one, something I will want just didn't think it would happen for a while but who knows
  Heim Steering wepuckett 20 9,489 08-28-2015, 03:18 PM
  Steering box help snipes243 24 17,796 07-17-2015, 09:42 AM
  Steering shaft Extension Question??? Broncitis 4 4,669 04-17-2015, 02:27 PM
  Quick disconnect steering wheel snipes243 4 5,438 08-21-2012, 06:50 PM
  Power Steering issues Crawdad 31 13,375 07-28-2011, 09:29 PM
  Home made heavy duty steering Timstrk 4 4,199 11-25-2010, 10:47 AM
  power steering pumps snipes243 9 7,905 11-15-2010, 05:17 PM
Last Post: nhopman
  Dana 44 Power-Lock jdowns67 2 2,124 09-26-2010, 10:18 PM
  steering column bluebooger 0 2,341 01-19-2010, 11:57 PM
Last Post: bluebooger
  HELP INSTALL POWER STEERING PBONE2000 3 2,820 12-11-2009, 01:08 PM
