Quick disconnect steering wheel
Has anybody here ever done this to a stock colume? I have seen the grant discounts but they require a key not really wanting to do that.
No...But why?
I used a stock column and a quick disconnect wheel. I had to weld the nut on the end of the shaft and I removed everything off of the shaft so it's essentially a naked shaft from the firewall up.
Here is a link to Classic where I posted some pics.
chuzie Wrote:No...But why?
To make it easier to get in and out. But I would like to keep the turn signals on the steering colume.
SC74 Wrote:I used a stock column and a quick disconnect wheel. I had to weld the nut on the end of the shaft and I removed everything off of the shaft so it's essentially a naked shaft from the firewall up.
Thats what I was thinking but keep the stock turn signals on it.
  Heim Steering wepuckett 20 9,446 08-28-2015, 03:18 PM
  Steering box help snipes243 24 17,747 07-17-2015, 09:42 AM
  What type Power Steering Cooler are you all using? Broncitis 7 4,141 07-16-2015, 01:32 AM
  Steering shaft Extension Question??? Broncitis 4 4,655 04-17-2015, 02:27 PM
  Power Steering issues Crawdad 31 13,323 07-28-2011, 09:29 PM
  Home made heavy duty steering Timstrk 4 4,182 11-25-2010, 10:47 AM
  power steering pumps snipes243 9 7,887 11-15-2010, 05:17 PM
Last Post: nhopman
  Wheel hop issues JustJeff 2 2,937 01-25-2010, 01:53 AM
Last Post: JustJeff
  steering column bluebooger 0 2,335 01-19-2010, 11:57 PM
Last Post: bluebooger
  HELP INSTALL POWER STEERING PBONE2000 3 2,812 12-11-2009, 01:08 PM
