79 Bronco Dana 44 Question
Can the rotor and hub be seperated? If so how do i do this?
Thanks
Yes. Remove the hub body. Remove the spindle nuts that are behind it, they look like this:
http://partimages2.genpt.com/partimages/225161.jpg
and are removed with this:
http://images.solidcactus.com/autobarn/cta4150.jpg
Then remove the brake calipers and pull the rotor off. A bearing should fall in your lap and you have your hub and rotor completely separated.
'95 Bronco with stuff, details here: http://www.supermotors.net/vehicles/registry/2805
Then if you need to replace the rotor just hammer out the wheel studs and the old rotor will fall off. Place the new rotor on and press the wheel studs back in or use a wheel stud installer to pull them back in with the lug nuts.
If you are just going to get the rotors turned or resurface leave the rotor on the hub. That way when its resurface its turned down true to the hub.
'85 Bronco. 14bolt/60. Distributorless EFI 393. ZF5. DOM cage. 38.5 TSLs. H1 double beadlocks. Lots more. Still a work in progress.
ASE Master Truck Tech. ASE Master Auto Tech.
Thanks for the answer, I found out this weekend haw they came apart.
John
  BC Bronco Soft Top knoxville714 3 5,124 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,989 01-31-2016, 03:55 PM
  Another Bronco Floor Replacement jdowns67 83 32,769 12-20-2014, 11:33 AM
  Exhaust question Casey835 27 14,954 08-16-2013, 06:03 PM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 4,483 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 4,452 05-19-2013, 08:43 PM
