Motor Mount locations
Trying to get my junk ready for re-assembly... I got a good pair of frame mounts from HighPressure and want to weld them on... but I don't necessarily trust the PO's location. They had converted to a 302 and before I cut off their crappy mounts and weld on HP's, I want to make sure that I have the right location. I'll take a measurement tomorrow (headed to shop to help out gumby), but wanted to see if any of you gurus know, or can easily measure, the proper location back from the end of the frame rail to the motor mounts. All else fails, I'll mock it up, but thought I might know someone who knows someone... :popc1:
'preciate it! :biggthumpup:
Thanks,
JayT
So, before I mock up the engine/trans/xfer... is 36" from the xfer case crossmember bolt holes to the bolt holes on the engine's frame mounts right for a 302?
JayT - I'll measure tomorrow when I go work on the bruggy.
Thanks! The Bruggy is looking awesome! Can't wait to see those H4s.... Killer.
I took a quick measurement. There is an oval slot on the top of the frame rail near the front cross member. The center line of the motor mount slot is 6" back from the rear of the slot in the frame.
From the center of the transmission mount hole to the center of the motor mount slot I have 34 5/8".
The 36" measurement sounds like the I6 length.
I think Bucketobolts is correct about the I6 lemgth.
I measured my I6 and the oval slot measurement is about 3.5"
The trans mount to motor mount is about 36.0"
Remember ... this is for the I6 engine.
Cool... Thanks, fellas! I knew I came to the right place!
JayT - I got 27-1/2" from the end of the frame rail (Driver side) to the center of the motor mount. The dr. and pass. are 1/4 to 1/2" offset from each other. If I remember correctly, the distance between the edge of the crossmember and outer lip of the motor mount was 7-3/4" (one side was 8" and the other was 7-3/4").
HTH if I'm not too late responding.
Thanks guys... I'll use all this info when I get back to the shop this weekend. As you can probably see in my build thread, I don't think the current locations are right. I'm glad I asked! Ya'll rock!
JayT
  Which Motor Should I Use? obxbronco 7 4,440 02-24-2016, 10:01 PM
Last Post: obxbronco
  motor help!!!!! broncatron 6 6,249 07-09-2013, 10:03 PM
Last Post: broncatron
  motor issues please help!! bigredbronco 9 5,139 12-22-2012, 11:30 AM
Last Post: bigredbronco
  Blown Motor. NateMob 22 11,734 11-02-2011, 09:26 PM
Last Post: NateMob
  Specs for 351W motor mount bolts? 73Bronc 11 6,063 09-27-2011, 11:36 PM
Last Post: 73Bronc
  spare tire mount snipes243 12 8,394 11-28-2010, 06:05 PM
  Swapped the motor in my Centurion and added a turbo! smooth 4 3,270 12-11-2009, 01:43 PM
  90 Transfer Case Motor Question 2000F150SAS 0 1,659 08-03-2009, 01:05 PM
Last Post: 2000F150SAS
  good motor find and c4 cuz1 13 7,082 12-08-2008, 08:31 AM
Last Post: DeTowman
  Fabbing New Rear Shock Mount Bighorn 5 4,892 11-19-2008, 07:01 PM
Last Post: Bighorn
