motor help!!!!!
ok, broncatron starts up cold perfectly, new high tourqe starter, starter solenoid, optima red top battery, alternator, battery cables, new water pump and radiator. it will not start up hot. 1990 eb 351, what else is there? PLEASE HELP!!!!!!!!
oh yeah, sounds like the battery is dead, but I know it isn't! it sounds like, wah wah wah wah wah etc.it started after I had the e40d rebuilt
Hard to say. My s10 did something similar. Turns out the ring gear on the flywheel was press fit and the 'fit' no longer fit when hot. The ring gear turned, but the engine didn't. It took a bit of figuring to find that. Take the dust cover off and see what is or isn't happening on yours while a helper turns the key.
pull your starter off and inspect the teeth...you may have a bad fit like bart mentioned.
welcome to the site
Priciate the welcome! Starter is good, almost seems like timing or not enough fuel to the block. Already changed plugs and wires, all started after tranny was rebuilt. No problem before. Also torque converter locks up in 2nd and 3rd when I give it a little more gas. Do know if that has anything to do with it.its going back in the shop next week to get my oil leaks fixed, rear main seal Etc... I will have my guy go ahead and adjust the timingany other advice would be greatly appreciated. Details to follow and some pics.
Not saying starter might be bad...saying they could have wrong flex plate, or starter could be too close to flex plate. As engine get hots...things expand.. this might be something to look at.
I have heard that the starter gets too hot obviously metal expands under heat therefore would not operate correctly therefore any ideas of what steps I should take to keep the starter cool?
  Which Motor Should I Use? obxbronco 7 4,445 02-24-2016, 10:01 PM
Last Post: obxbronco
  motor issues please help!! bigredbronco 9 5,142 12-22-2012, 11:30 AM
Last Post: bigredbronco
  Blown Motor. NateMob 22 11,743 11-02-2011, 09:26 PM
Last Post: NateMob
  Specs for 351W motor mount bolts? 73Bronc 11 6,065 09-27-2011, 11:36 PM
Last Post: 73Bronc
  Swapped the motor in my Centurion and added a turbo! smooth 4 3,276 12-11-2009, 01:43 PM
  Motor Mount locations JayT 8 4,265 08-19-2009, 01:09 AM
  90 Transfer Case Motor Question 2000F150SAS 0 1,664 08-03-2009, 01:05 PM
Last Post: 2000F150SAS
  good motor find and c4 cuz1 13 7,092 12-08-2008, 08:31 AM
Last Post: DeTowman
  Finished 69 project after blowing my motor gigabytethis 3 4,004 11-10-2008, 02:41 PM
Last Post: gigabytethis
  Motor Swap Question?? BigBird13 5 3,558 10-16-2008, 07:36 PM
Last Post: BigBird13
