Trailer hitch question
I would like to use my hitch mounted basket/ tray for URE though I have no hitch on my EB. I don't really need a hitch at least for now so would it be worth while to weld some square tube to accept the basket or just bite the bullet and buy a hitch.
Is there a cost effective hitch recommendation out there for our application under $100.00?
You should be able to make one for about $30. Fields has the hitch inserts and "select drops". Then just weld it up and bold it on.
Fields?
Gee I thought your front bumper was a basket:hysterical:
If your going to weld in a receiver be sure and do it right. It can then be used as a pull point. My suggestion would be hit up a salvage yard for one.
Usually get one for about $20.
Fields Ornamental Iron and Welding Inc on CrossCounty Rd.
A ranger of F150 trailer hitch from the junkyard would be easy to adapt as well.
Think I will hit the yard for something to adapt. At least then I know it is somewhat solid. I suck at welding so that is half the battle. Thanks guys.
BTW- My front bumper is more like stadium seating than a basket. It makes life on the trail much more interesting since i have such limited AOA availability.
  Steering shaft Extension Question??? Broncitis 4 4,659 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 14,956 08-16-2013, 06:03 PM
  1991 351W EFI Question Crawdad 4 3,885 03-27-2012, 09:05 AM
  Receiver hitch installation 73Bronc 3 4,077 10-19-2011, 09:33 AM
Last Post: 73Bronc
  Hard top Question 744x4 5 6,169 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,821 08-25-2011, 01:58 PM
Last Post: ncsubronc
  Fiberglass Dr Insert Question 744x4 5 3,700 08-10-2011, 01:24 PM
Last Post: dixieboyz13
  9" pinion question scbronco 10 6,064 01-07-2011, 08:23 PM
  TTB lift question jdowns67 7 4,727 11-20-2010, 09:36 PM
  v8 water pump question jrshepherd 7 4,001 11-08-2010, 10:18 AM
