11-02-2010, 01:00 PM
I for got to take a picture and its been a while. Where does the atl bracket attach? Can some one send me a pic? Would you use any extra sealant (RVT)?
Thanks again!
Thanks again!
v8 water pump question
Thanks again!
11-04-2010, 12:11 AM
kinda lost on what you are referring to with the extra sealant. if you are talking about putting something on each side of the gaskets, i would use aviation gasket sealer- it is available from any parts house and brushes on. it works great but is a bear to remove. i am not a big fan of silicone RTV.
I am not up with the times electronically, but you are welcome to come by my place to look at how the bracket goes. I am in charlotte, on the east side, near mint hill. i can text a pic if need be. pm me if you would like. the upper (triangular) alt bracket attaches to the left side of the water pump. it is easy to line it up. just use a long dowel or the original long threaded rod to line the end that attaches to the alternator up to the hole in the cylinder head. just leave the alternator aside and match the hole in the head up. the bolt holes in the water pump will be easy to match up from there. the lower bracket attaches to the lone hole near the water inlet for the pump.
11-04-2010, 12:55 AM
be sure not to use too much sealer. it can get in the water system if there is excess and clog the cooling passages.
11-04-2010, 10:35 PM
Thanks. I usually would not use a drop, but the directions say to use some. I'm going to use Hylomar. Worked great in my Lotus days. Thanks for the info.
Shep
11-04-2010, 10:37 PM
Thanks. What year bronco do you own?
broncosbybart Wrote:kinda lost on what you are referring to with the extra sealant. if you are talking about putting something on each side of the gaskets, i would use aviation gasket sealer- it is available from any parts house and brushes on. it works great but is a bear to remove. i am not a big fan of silicone RTV.
11-05-2010, 09:27 AM
a couple. the one that we would be looking at is a 68. the 76 is getting an efi swap, and the 70 will be getting a cummins 4BTA put in it...
11-05-2010, 11:52 AM
Sounds like u have your hands full. Cummings diesel?? I have a rusty 74.
11-08-2010, 10:18 AM
yeah, you might say that i have a few projects... you are more than welcome to swing by. happy to help you out.
| Steering shaft Extension Question??? | Broncitis | 4 | 4,659 |
04-17-2015, 02:27 PM Last Post: Broncitis |
| Exhaust question | Casey835 | 27 | 14,956 |
08-16-2013, 06:03 PM Last Post: blazinchuck |
| 1991 351W EFI Question | Crawdad | 4 | 3,885 |
03-27-2012, 09:05 AM Last Post: broncosbybart |
| Hard top Question | 744x4 | 5 | 6,169 |
09-06-2011, 10:32 PM Last Post: Mill Knob |
| Tire question | dixieboyz13 | 12 | 7,821 |
08-25-2011, 01:58 PM Last Post: ncsubronc |
| Fiberglass Dr Insert Question | 744x4 | 5 | 3,700 |
08-10-2011, 01:24 PM Last Post: dixieboyz13 |
| 9" pinion question | scbronco | 10 | 6,064 |
01-07-2011, 08:23 PM Last Post: Crawdad |
| TTB lift question | jdowns67 | 7 | 4,727 |
11-20-2010, 09:36 PM Last Post: broncomatt |
| water pump v8 302 torque spec | jrshepherd | 5 | 5,162 |
11-13-2010, 10:45 PM Last Post: Casey835 |
| 90 Bronco TTB Yoke Question | 2000F150SAS | 2 | 3,051 |
02-16-2010, 10:07 PM Last Post: broncomania |
