Fiberglass Dr Insert Question
Those of you running fiberglass inserts will be able to answer this but I am guessing I have to have the ft fenders mounted before I can install the inserts due to the Bolts going behind the fenders to hold them on. I also have a Damn near mint set of Black Kayline soft doors and Mounting Hardware if anyone need a good set as I am just going to use the inserts and not the doors for the Mini tub.
03 Honda Shadow Spirit
Hey Keith, those doors go cheap!!! But the hardware is priceless!!! Ask me how I know!!!!!
Sounds like someone had to Pony up some coin to replace them.
744x4 Wrote:Those of you running fiberglass inserts will be able to answer this but I am guessing I have to have the ft fenders mounted before I can install the inserts due to the Bolts going behind the fenders to hold them on.
this is correct.
i wouldnt get rid of the soft doors...you NEVER know, you just may need them for a cold ,raining,nasty day wheeling- my .02Confusedmokin:
But if I put the Hardware on the inserts they look Goofy without the Doors and Filling them now is easy with some Resin and a few strands of Matt
Are the soft doors still available? I have been looking for a set, but haven't felt like ponying up the $$$ for new ones.
  Steering shaft Extension Question??? Broncitis 4 4,657 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 14,951 08-16-2013, 06:03 PM
  1991 351W EFI Question Crawdad 4 3,880 03-27-2012, 09:05 AM
  Hard top Question 744x4 5 6,167 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,819 08-25-2011, 01:58 PM
Last Post: ncsubronc
  9" pinion question scbronco 10 6,060 01-07-2011, 08:23 PM
  TTB lift question jdowns67 7 4,723 11-20-2010, 09:36 PM
  v8 water pump question jrshepherd 7 3,995 11-08-2010, 10:18 AM
  90 Bronco TTB Yoke Question 2000F150SAS 2 3,047 02-16-2010, 10:07 PM
  79 F150 Dana 44 Axle Question 2000F150SAS 3 4,292 01-31-2010, 03:53 AM
