Ignition missing and jumping tach
Hey guys, I have a new problem and I thought I'd post it here before I did any serious troubleshooting. I have a HEI distributor that has been installed for almost a year now with no issues. Lately, my motor has been missing a little and I can see the tachometer jump up every few seconds. When I really take off, I can really feel it surging/missing. Has anyone else run into this on a HEI distributor?
JD
if your tach is acting up along with the engine you might wanna check your coil. because thats where it gets its information from. or if you have a bad ballast resistor.
jdowns67 Wrote:Hey guys, I have a new problem and I thought I'd post it here before I did any serious troubleshooting. I have a HEI distributor that has been installed for almost a year now with no issues. Lately, my motor has been missing a little and I can see the tachometer jump up every few seconds. When I really take off, I can really feel it surging/missing. Has anyone else run into this on a HEI distributor?
JD
any idea of which dist. it is?? there are some junks out there. it could very well be carb (fuel) related, or a bad plug(s) or wire(s). what all have you done to it recently (if anything)?? You can also try disconnecting the tach wire and see if it goes away.
It's an HEI distributor. I opened it up last night and found a loose connector from the magnetic pickup to the module. It's running fine now but I am still keeping an eye on it.
Thanks for the advice,
JD
I was thinking more of the manufacturer. If it is a Pro Comp, they had a lot of issues. Hopefully it was a loose connection. I have a Proform one in my crawler (came from Jeff's). So far so good. The first one I bought was an ebay special. No spark right out of the box....
It's a Performance Distributors distributor (DUI)
  Ford D.U.I. Ignition scbronco 14 11,609 09-06-2012, 06:03 PM
  Ignition switch?? jollygrngiant 10 6,210 09-09-2011, 03:20 PM
Last Post: UTFLIWGYA
  What is missing here??? Crawdad 5 4,211 04-17-2011, 10:11 AM
  A good article about ignition timing jdowns67 0 3,139 10-17-2010, 08:52 PM
  93 bronco missing on light load psychobiker 3 2,796 01-21-2010, 10:22 PM
  Pertronix Solid-State Electronic Ignition jrshepherd 6 7,157 11-08-2009, 11:26 PM
  Pertronix Ignition Problems. Mill Knob 13 6,908 09-09-2009, 01:32 PM
  Ignition Fuse Blown?? SC74 6 4,512 02-12-2009, 11:14 PM
Last Post: Mill Knob
  elec. Ignition berg bronco 4 3,638 01-25-2009, 08:36 PM
Last Post: berg bronco
  Ignition rcflyer23 7 5,890 11-02-2008, 08:15 PM
Last Post: rcflyer23
