8 lug and SAS
Has anyone done the 8lug conversion?
How to and what will I need? Just looking into it.
Im also looking into an sas on a fsb 1980 model.
Sent from a Bionic powerhouse
Is that a tank?....NO...its worse....Its my Bronco
no advantage in going 8 lug unless its installing 1 tons. not sure what rear axle you have...the front should be pretty easy since its a form of d44(TTB). i doubt there is a conversion for the rear...i could be wrong
I have a 9" rear. Just going straight in the front
in that case, you might be able to find a alum adapter to convert the 5 to 8 and also if you get the right thickness...you can make it match the front width. almost all front axles are normally wider than rears
The 8lug was just a thought I want to do a straight up front though
  Pictures from my SAS Ogeechee 4x4 13 9,730 05-15-2008, 05:18 PM
Last Post: Traveler
  cutting edge suspension for SAS DocLewis 8 7,861 03-25-2008, 11:34 PM
Last Post: johnski
