Looking for Troubleshooting Tips for a 79' Bronco Rear Window (Powered).
All you Big Bronco guys out there have dealt with this problem at one time or another.
My Rear Window in a 79 Bronco is down and is powered. I have checked the fuses, inspected what I can see through the accessible portion of the tailgate, I can see (and hear) the switch "click" on and off when I turn the key, and yes, I did actually see it work.
It is in the DOWN position and is nearly impossible to access anything to check it out.
Is there an easy way to troubleshoot? Bypass? Manually move the glass without breaking it?
Any tips would be great. Thanx
Brian
Brian,
My experience hs been the dash swith is the weak link and in particular the ground. Steve93 has some good schematics on 4doorbroncos and super motors. Try this link to get you to a better link!
http://www.fourdoorbronco.com/board/show...dow+switch
:xyxthumbs: ROCKNROLL!!
http://www.supermotors.net/registry/media/930203
http://www.supermotors.net/registry/media/160930
Good stuff here!! If it does nothing from either dash or key switch check ground at the dash and limit switch in the gate.......
Bronco Biff,
Thanx for the links. I will have to get my Gear-Head out and see what turns up. Question: I don't have a dash switch. My 79 has the "turn the key while you stand outside the darn thing lookin like an idiot" method. Inside I can see the switch, but the glass is down, so no bueno on gettin' after it.
Is there a way to "release" the window so that it can be moved in order to adjust/fix?
Thanx
This is the tailgate tech page from Steve83:
http://www.supermotors.net/registry/2742/12689
If you poke thru these there is mention of pushing in wiht your shouldger on the left side of the tailgate to further persuade the safety switch, removing the nuts on the bottoem of the glass to seperate from the regulator, or finding the motor conector at the bottom of the tailgat and jumping directly to the motor.
Bronco Biff...Thanx!! I'll letcha know how it goes. Brian
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,533 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,943 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,082 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,533 12-12-2016, 11:54 AM
  BC Bronco Soft Top knoxville714 3 5,133 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 7,017 01-31-2016, 03:55 PM
  Lighted rear view mirror chuzie 6 7,745 06-20-2015, 12:18 AM
  Another Bronco Floor Replacement jdowns67 83 32,881 12-20-2014, 11:33 AM
  rear main seal snipes243 5 5,049 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,847 03-06-2014, 08:09 PM
