Fuel injected or Carb
I have a 302 Carb, and a 302 fuel injected. I wanted to put the fuel injected in, but not all the computer stuff. A buddy of mine told me that i could take the fuel injection off and put a carb on it, i have a Holley 4 barrel. He also said all i had to do was mount an inline fuel pump. Anybody have any thoughts on this?
You can run a carb on a motor that was originally EFI. You will need the carb, intake, and distributor to make it work.
Well, i have all of that, i think i might try it. How hard is it?
For my money, I'd install the computer stuff and use the EFI. just my 2 cents! Smile
I've thought about it, but i actually like a carb.
If you don't run the inline electric fuel pump, you may have to change the timing chain cover to one that has a mechanical fuel pump mount. Then don't forget the eccentric on the camshaft to run the pump.
BUCKETOBOLTS Wrote:If you don't run the inline electric fuel pump, you may have to change the timing chain cover to one that has a mechanical fuel pump mount. Then don't forget the eccentric on the camshaft to run the pump.
OBX - I think I have a timing cover that will work if you decide to go that route.
Not sure what i want to do, i'm lost, so many decisions. Thanks Robert
Intake is easy to do and i would just go with the inline electric pump (low pressure of course). easy to install, easy to replace and less fuss for you on the front end. make sure it get it in close to the tank just in case you decide to go FI later it is already in position for the accumulator and high pressure pump, etc. Be careful with the FI intake on removal. Someone may want it and they break easily where the top screws mount. Also a good opportunity to snag a preformance intake if you want.
-mike
(For God's sake, someone please come resuce me from Altus, Ok!!!!)
What are your plans for the Bronco? If you plan on offroading or crawling the FI will have a definate advantage over the carb. But for the street the carb may be a little cheaper and easier.
  In-tank fuel Pumps snipes243 0 2,345 06-22-2015, 02:06 PM
  Efi and stock fuel tank snipes243 3 2,951 12-11-2012, 03:28 PM
Last Post: Carolinaoffroad
  fuel line leak firefighter2134 5 3,270 03-12-2010, 06:46 PM
  carb help maybe firefighter2134 7 5,669 03-10-2010, 07:46 AM
  Fuel line jrshepherd 2 3,105 12-11-2009, 01:07 PM
  Carb Question.. Help a Brother out.... Mill Knob 26 16,282 09-10-2009, 11:57 PM
Last Post: 66stocker
  Fuel leaking at cap LOTS OF PRESSURE!!! chuzie 21 10,548 07-13-2009, 08:55 AM
  1990 Fuel Pressure??? 2000F150SAS 2 2,809 07-06-2009, 10:38 AM
Last Post: 2000F150SAS
  Carb CFM? JayT 7 6,627 11-16-2008, 02:18 AM
Last Post: 744x4
  EFI Fuel Pump Question SC74 2 2,634 07-11-2008, 10:30 AM
