fuel line leak
ok guys cant seem to win for losing right now. got the carb issue straightened out now i have a fuel leak. i have a rubber hose connecting fuel pump to a plastic yeah plastic line dont think it was stock back to a rubber line then to sending unit. plastic line runs entire length of frame. was this some presidental engineering of some sort? its leaking at rear plastic line is split. any ideas? i want to correct this issue the right way. thanks in advance
asiel
The plastic line is stock. It's 5/16 nylon, nothing special.
Just cut the plastic back past the split and extend your rubber line.
If you want to replace the plastic you can get it at JBG or any of the bronco vendors for about $20.
Socialism is GREAT!
Until you run out of other peoples money!
I got a whole rubber line gonna run it inside frame rail one piece better than 3
well inside frame rail didnt work but new line is installed was able to use factory hangers though so not all bad runs great now! thanks guys
Good deal.
It won't be long till you have a brand new rig!
Socialism is GREAT!
wouldnt be so bad but i neglected to mess with it for the last couple years. worst thing you can do is let one sit.
  Rock guard for winch line snipes243 6 6,350 01-16-2016, 03:22 PM
  In-tank fuel Pumps snipes243 0 2,338 06-22-2015, 02:06 PM
  Efi and stock fuel tank snipes243 3 2,945 12-11-2012, 03:28 PM
Last Post: Carolinaoffroad
  Axle Seal Leak.. Again! 73Bronc 13 7,049 10-15-2010, 01:50 PM
  Fuel line jrshepherd 2 3,099 12-11-2009, 01:07 PM
  Help !!! Caused an exhaust leak johnpaulgolf 10 6,673 09-25-2009, 09:46 AM
  Fuel leaking at cap LOTS OF PRESSURE!!! chuzie 21 10,521 07-13-2009, 08:55 AM
  1990 Fuel Pressure??? 2000F150SAS 2 2,798 07-06-2009, 10:38 AM
Last Post: 2000F150SAS
  Rear axle leak 73Bronc 8 4,778 03-28-2009, 08:09 AM
Last Post: Barnes 4wd
  EFI Fuel Pump Question SC74 2 2,628 07-11-2008, 10:30 AM
