EFI Fuel Pump Question
As always I'm over-thinking this situation. I like how 744x4 has plumbed his high pressure fuel pump - he has a low pressure pump before the HP pump which keeps it primed. I'm doing the same thing and have it lined up in this order:
1. Fuel Cell
2. Low Pressure Inline Fuel Filter
3. Low Pressure Inline Fuel Pump
4. High Pressure Inline Fuel Pump
Now I've got to thinking - my only filter is the cheapo low pressure filter. What's the big difference in the low pressure and high pressure filters besides dollars? I've also got a HP filter that I would like to use, but does it make sense to put this between the HP pump and motor, or is that overkill? Would it hurt to replace the LP filter with the better quality HP filter even though it will only have high pressure? I know I need something before the LP pump to help prevent failure Confusedcratchhe:
Do any of you have a similar set-up or are you just running a HP pump and filter?
Thanks,
Robert
Robert,
I don't have the setup installed but I'm going to run a HP pump in the tank and a HP filter along the rails. I've only seen the lp /hp setup with an accumulator between them. That seems to work pretty well in a rock buggy.
I do not see a real need for the filter as long as you have a diaphram type pump. Unless it experiences some type of catastrophic failure nothing from the pump will FOD out your lines with junk.
All I run is a LP filter in my EFI setup. FWIW- I also have a small accumulator between the LP and HP pumps.
  In-tank fuel Pumps snipes243 0 2,339 06-22-2015, 02:06 PM
  Steering shaft Extension Question??? Broncitis 4 4,657 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 14,950 08-16-2013, 06:03 PM
  Efi and stock fuel tank snipes243 3 2,947 12-11-2012, 03:28 PM
Last Post: Carolinaoffroad
  EFI wiring harnesses BucknEB 16 8,965 07-04-2012, 08:32 PM
  1991 351W EFI Question Crawdad 4 3,880 03-27-2012, 09:05 AM
  Hard top Question 744x4 5 6,167 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,818 08-25-2011, 01:58 PM
Last Post: ncsubronc
  Fiberglass Dr Insert Question 744x4 5 3,696 08-10-2011, 01:24 PM
Last Post: dixieboyz13
  5.0 EFI upgrades? blazinchuck 4 3,084 07-25-2011, 10:57 PM
Last Post: nhopman
