Rear brake line
I trying to figure out how the rear flex line connects to the frame. Does anybody have any pictures on how the stock line is held in place. So how else does everybody keep the lines secured to the frame. I found some hose tabs that you have to weld on, but I need something that screws or rivet on.
thanks clay
anyone
there is an angled bracket with about a 3/4" hole in it that is located on the corner of the frame rail and the rear crossmember (in front of the rear tank). the oem hose is routed through that hole and secured by a metal clip. you're welcome to look at one of my trucks if you'd like to see it.
I would like to come see that sometime. If you get some free time give me a call if you still have my number.
thanks clay
just shoot me a pm or email w/it. i'm not sure i still have it. i've got a 72 sitting in my driveway (the one i just found in the DC area) that you can take a good look at. i should be home friday evening and pretty much all weekend, except for sat morning and church on sunday.
Pm sent Hey did you happen to get my pm to you over at classicbroncos.
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,029 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,484 12-12-2016, 11:54 AM
  Rock guard for winch line snipes243 6 6,310 01-16-2016, 03:22 PM
  Parking brake snipes243 24 16,411 11-29-2015, 06:21 PM
  Lighted rear view mirror chuzie 6 7,691 06-20-2015, 12:18 AM
  rear main seal snipes243 5 5,011 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,786 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,572 01-11-2014, 12:26 AM
  Manual brake push rod??? chuzie 13 8,550 01-06-2014, 03:04 PM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,131 12-01-2013, 10:38 PM
