Master cylinder help
Ok So my master cylinder went bad. So Im trying to decide either to get a stock one or get an upgraded one, what do you guys think? I have drums front and rear but have started looking the parts to do a front disk conversion.
try a late 70's F-250...I ran that for a while, even had it when I added disc in the front.
I ran a Corvette MC with disc in the front. It was kind of like redneck PB too - I could hardly tell a difference when I added a booster with a Bronco MC.
Is there any modifications need for either?
The Corvette was a bolt on - don't know what year or make but I might be able to dig it up tonight and get a part #. It's just got a bigger bore in the MC so it pumps more fluid to the brakes than stock.
I converted to the '78-79 F250 master cylinder when I first did my front disc conversion. Be sure to get a "camper special" or dual piston caliper application. I has a large 1 1/8" piston which works really well without a booster. I had no problems stopping with 35-36" tires. I even ran it when I added my rear discs with no issues.
Now I have added the hydroboost assist and run an '80 Corvette master cylinder. It is designed more for the disc/disc brakes. I swapped because my booster was off of an Astro van and had a narrower mounting bolt pattern.
Another tidbit, I still do not run a proportioning valve. Mostly because I have been too lazy to redo my lines. I have an aftermarket adjustable version to limit the rear and keep them from locking up to easily. But like I said before, I've had no problems yet. In the rain I try to be careful with the panic stops to prevent spinning out, but you have to drive really careful in the rain anyhow with a spool in the rear.
Do I have to reuse the push rod for either the corvette or camper edition?
Its been a little while but I don't think I had to modify the rod. You may want to browse the Tech articles on ClassicBroncos.com I'm pretty sure there was an article on there about the conversion.
ive got a full width hp44 with disc brakes on it . $200.00
broncomania Wrote:ive got a full width hp44 with disc brakes on it . $200.00
Tempting but just finished gears and an arb swap so Im happy.
He does anyone have any part numbers for one of these?
  Who is using Surplus Center for ram assist cylinder? chuzie 6 3,550 08-16-2015, 09:30 AM
  1996 5.8 L Engine Rebuild- Cylinder heads jrshepherd 0 3,424 07-17-2011, 11:13 AM
