1996 5.8 L Engine Rebuild- Cylinder heads
Hello. Im in the process of having the 5.8l engine rebuilt on my bronco. The exhaust valves on the passanger side were sunken, so I have deceided to upgrade rather than using used parts. The engine ran hot before I bought it and I'm haveing to punch the block .30 over. My engine builder wants to use trick flow heads, forged pistons and match cam. I know trick flow products are specific to one another and can't be used with any other brands. Does anyone have any suggestions? Confusedcratchhe: I will take any advice on the whole build.
Thanks.
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,936 05-22-2018, 09:38 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,987 01-31-2016, 03:55 PM
  Who is using Surplus Center for ram assist cylinder? chuzie 6 3,549 08-16-2015, 09:30 AM
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 6,088 05-15-2014, 11:50 AM
Last Post: rbodine
  Engine help snipes243 12 6,460 02-21-2014, 12:06 AM
  Can firing order determine engine block size? 1st Bronco 1 2,017 08-16-2013, 06:26 PM
  5.0/nv3550...engine now dies at stops*help* blazinchuck 14 7,033 06-09-2013, 10:50 AM
  Engine Rebuild. 1996 5.8 L jrshepherd 0 1,740 05-05-2011, 02:02 AM
