08-21-2008, 10:57 PM
Now that i need this i can't find who sells them.. The piece that threads into the d44 case that hold the brake block and the vent line hooks to. Where can i find one. Ken:banghead:
front axle vent
08-21-2008, 11:44 PM
that should be easy find on any old 9" or D44 axles(junk yards)...I might even have one. I let ya know Ken,Chuck
08-21-2008, 11:49 PM
If chuck doesn't i probably do. i'll look when it gets daylight.
08-21-2008, 11:56 PM
Thanks. dont know what happen to mine, po used a solid bolt.ken
08-22-2008, 09:05 AM
I think national parts depot sells them for about $10. Check out their online catalog.
http://npd.dirxion.com/Main.asp Bill
Thanks, Ole bronco buddy Tim has graciously donated one. Just for info i did find that wildhorses has em $12.
Ken
08-29-2008, 10:50 PM
Run a # 31 bit down the center hole to get the crud out of it so it functions properly.I had a leaky 9 for a long time and found out the vent was clogged making it build pressure and the axle seals would leak.20 seconds with the bit fixed it right up.Now I do this to every axle I rebuild and you wouldnt believe the crud that comes out of them.
08-31-2008, 12:37 PM
It was clean when I sent it to him. Inside and out.
Tim 74 Bronco Ranger halfcab w/toys |
Front axle | krazybronco | 1 | 803 |
02-20-2011, 11:44 PM Last Post: broncosbybart |
Stiff front end. | Rollers888 | 14 | 2,384 |
01-31-2011, 03:27 PM Last Post: Rollers888 |
RockSolid PreRunner Front Winch Bumper 92-96 | Sweat | 28 | 11,098 |
06-02-2010, 06:51 PM Last Post: jollygrngiant |
Cronic leak in the right rear axle | 73Bronc | 15 | 3,004 |
08-04-2009, 11:50 PM Last Post: JayT |
gears front and rear | bone collector | 8 | 2,975 |
07-31-2009, 08:07 PM Last Post: chuzie |
Doubler/axle moved forward Questions | blazinchuck | 11 | 3,131 |
04-30-2009, 08:32 PM Last Post: bucketobolts |
front sway bar | KUIKUIBRONCO | 15 | 2,625 |
04-20-2009, 11:52 PM Last Post: KUIKUIBRONCO |
FSB front rotor removal | tapiot | 18 | 5,858 |
04-19-2009, 09:26 PM Last Post: bone collector |
JP's New Front Bumper!!!! | SC74 | 60 | 8,309 |
12-20-2008, 11:00 PM Last Post: SC74 |
New front driveshaft | badbronco | 1 | 2,987 |
07-10-2008, 11:05 PM Last Post: johnpaulgolf |
