Swaybars and lift kits
Has anyone successfully installed (or kept) their rear sway bar when you lifted your bronco?
I'm wanting to re-install mine, but I know I'll need longer end-links. No one manufactures extended end-links for a Bronco/f150. Skyjacker does, however, make them for a F250/350 with a 6" lift.
Do y'all think a 3/4 ton end link would work on a 1/2 ton sway bar?
If not, how do I make my own? I'm worried that I'll use too small of stock and they'll bend... Confusedcratchhe:
Measure the o.d. and thread size, add whatever lift you have to the length of the stock ones. Should be pretty easy to make. If you want, i can measure the stock ones on my c-350 and compare...........Bet they are close...
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 4,280 01-31-2016, 03:55 PM
  Ideas for hauling a Hi Lift jack? Broncitis 6 2,864 06-19-2015, 05:03 PM
  Lift & Tires??? scbronco 9 2,942 05-22-2011, 09:27 PM
  TTB lift question jdowns67 7 2,633 11-20-2010, 09:36 PM
  6" Lift - Bushing or Drop Bracket 2000F150SAS 4 1,874 09-14-2009, 08:54 PM
  87 lift question clarkjw24 10 3,250 06-04-2009, 10:59 PM
Last Post: john90
  lift ? Action 7 5,280 03-09-2009, 10:59 AM
  body lift with 3spd. snipes243 0 840 03-03-2009, 10:37 PM
  6" Bronco Lift Question 2000F150SAS 6 2,450 11-02-2008, 08:37 PM
  body lift snipes243 5 3,615 10-30-2008, 04:28 AM
