87 lift question
If you needed 6" of lift on an 87 how would you do it? Would a complete kit like rough country sells be the best? Or do you just need drop brackets, new coils and blocks? I'm asking for a friend that wants me to lift his 87. I don't know crap about ford suspensions. I was wondering if there is an alternative.
You would need the entire kit,coils,center pivot brackets,radius arm drop brackets and pittman arm etc.I have a rough country kit and for the money its not bad.
[Image: Outalne_017.gif]
sparkchaser Wrote:You would need the entire kit,coils,center pivot brackets,radius arm drop brackets and pittman arm etc.I have a rough country kit and for the money its not bad.
So do you really need the new complete radius arms like what comes in the tuff country kits? Its about a $400 difference between ruff and tuff kits.
you dont NEED the radius arms. i have a rough country lift on my 87 as well and i havent had any issues really. i have wheeled my truck and it has all held up well.
John your such a noob. it even says so under your name!!
Eric. :rebel:
Badass Wrote:John your such a noob. it even says so under your name!!
WHAT but I was thinking he was :notworthy:
[Image: superman.jpg]
But once again let down by someone I USED to look up to ... well only if I was lying down and he was on a step ladder ... :hysterical: :thefinger: :hysterical:
:popc1:
johnpaulgolf Wrote:WHAT but I was thinking he was :notworthy:
:popc1:
Thanks for the help :banghead: Getting wisdom from you two old fookers I feel like I'm watching a Cheech and Chong movie.:thefinger:
Daves' not here.
no Im Dave.
Daves' not here
Eric. :rebel:
John, I'm running the 6" Rough country on my 90... but put a set of rear springs from superlift instead of the rear-blocks... Wish I had extended radius arms, but they're not "needed"...
clarkjw24 Wrote:Thanks for the help :banghead: Getting wisdom from you two old fookers I feel like I'm watching a Cheech and Chong movie.:thefinger:
Boy, you got that right!! :xyxthumbs:
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 7,068 01-31-2016, 03:55 PM
  Ideas for hauling a Hi Lift jack? Broncitis 6 4,527 06-19-2015, 05:03 PM
  Steering shaft Extension Question??? Broncitis 4 4,687 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 15,140 08-16-2013, 06:03 PM
  1991 351W EFI Question Crawdad 4 3,929 03-27-2012, 09:05 AM
  Hard top Question 744x4 5 6,206 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,886 08-25-2011, 01:58 PM
Last Post: ncsubronc
  Fiberglass Dr Insert Question 744x4 5 3,743 08-10-2011, 01:24 PM
Last Post: dixieboyz13
  Lift & Tires??? scbronco 9 5,349 05-22-2011, 09:27 PM
  9" pinion question scbronco 10 6,117 01-07-2011, 08:23 PM
