1976 F100 Dana 44 Question
I just picked up a 1976 F100 Dana 44 front rear and it has drum brakes, how hard is it to swap to disk brakes? Cost for this +/-?
Thanks, John
You can do the popular "Chevy" conversion really cheap.
http://classicbroncos.com/disc.shtml
Or you can swap the knuckles out from a '77-79 Ford D44.
You will probably also want to upgrade to the F250 "camper special" master cylinder. It makes you work a little less when running big tires.
This rear will be going into a 2000 F150.
So i have to swap the whole knuckle to run disc brakes (just the knuckle)? I guess the caliber bracket is on the knuckle?
Thanks, John
If you use the '77-79 Ford knuckles, I believe the brackets are cast on the knuckle. Then you need the spindle that the rotor/hub rides on and holds the axle in. And of coarse the rotor/hub, caliper, and hoses.
u should have bought mine it already had disc brakes!1Confusedupergrin::rebel:
http://www.wheelindixie.com
  Steering shaft Extension Question??? Broncitis 4 3,125 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 8,440 08-16-2013, 06:03 PM
  dana 44 mods 64500xl 8 2,195 07-06-2012, 08:44 PM
  1991 351W EFI Question Crawdad 4 2,369 03-27-2012, 09:05 AM
  Hard top Question 744x4 5 4,497 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 5,058 08-25-2011, 01:58 PM
  Fiberglass Dr Insert Question 744x4 5 1,841 08-10-2011, 01:24 PM
Last Post: dixieboyz13
  9" pinion question scbronco 10 3,353 01-07-2011, 08:23 PM
  TTB lift question jdowns67 7 2,635 11-20-2010, 09:36 PM
  v8 water pump question jrshepherd 7 2,181 11-08-2010, 10:18 AM
