03-06-2009, 07:00 PM
how do you tell the difference between a 302 and 289 block thanks.
Dumb question alert.
03-06-2009, 07:05 PM
As far as I know the blocks are the same. The only difference between the two was the stroke length. It should have a casting number under the intake as to which it was from the factory. You can make a 289 a 302 by changing the crank and vice versa. You can also make either a 347 by doing the same thing plus .030" over, I think.
03-07-2009, 06:54 PM
Okay so I looked all over the block and all I could find were these numbers
DI0-8015-AA. On the heads were the numbers 351. Any help? Thanks
03-08-2009, 11:36 AM
The casting on the block designates it as a 302 block. Most all the 289's were C6-C5 and prior castings. The 302 began with the C8 casting and progressed.
so its a 302 block with 351 heads?
03-08-2009, 09:58 PM
Probably. Just means its been rebuilt once already. I ran that combination on a previous engine.
Steering shaft Extension Question??? | Broncitis | 4 | 3,124 |
04-17-2015, 02:27 PM Last Post: Broncitis |
Exhaust question | Casey835 | 27 | 8,440 |
08-16-2013, 06:03 PM Last Post: blazinchuck |
1991 351W EFI Question | Crawdad | 4 | 2,369 |
03-27-2012, 09:05 AM Last Post: broncosbybart |
Hard top Question | 744x4 | 5 | 4,497 |
09-06-2011, 10:32 PM Last Post: Mill Knob |
Tire question | dixieboyz13 | 12 | 5,058 |
08-25-2011, 01:58 PM Last Post: ncsubronc |
Fiberglass Dr Insert Question | 744x4 | 5 | 1,841 |
08-10-2011, 01:24 PM Last Post: dixieboyz13 |
9" pinion question | scbronco | 10 | 3,353 |
01-07-2011, 08:23 PM Last Post: Crawdad |
TTB lift question | jdowns67 | 7 | 2,635 |
11-20-2010, 09:36 PM Last Post: broncomatt |
v8 water pump question | jrshepherd | 7 | 2,181 |
11-08-2010, 10:18 AM Last Post: broncosbybart |
90 Bronco TTB Yoke Question | 2000F150SAS | 2 | 1,947 |
02-16-2010, 10:07 PM Last Post: broncomania |
