90 Bronco TTB Yoke Question
Ok, I have a yoke question:
We are starting our SAS on a 90 Bronco and will be installing a 79 F150 Dana 44. Before I have the gears installed I would like to get the right yoke and since i'm selling the TTB I can't remove the original yoke. What are the specification difference between:
1310 yoke?
1330 yoke?
1350 yoke?
If this has already been addressed please provide link, I could not find anything.
Thanks
if you have a 1979 hp44 then your yoke is a 1330
1978 and older was 1310.
the slip yoke from your bronco is more than likely a 1330 and will fit right up to the yoke on your 79 dana 44.
oh and if you need any yokes or slip yokes or driveshaft tubes , pm me. i still have a stack of them.
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,427 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,855 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 8,796 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 5,003 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,808 01-31-2016, 03:55 PM
  Steering shaft Extension Question??? Broncitis 4 4,544 04-17-2015, 02:27 PM
  Another Bronco Floor Replacement jdowns67 83 31,913 12-20-2014, 11:33 AM
  Exhaust question Casey835 27 14,488 08-16-2013, 06:03 PM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 4,411 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 4,363 05-19-2013, 08:43 PM
