![[Image: SIMG0037.jpg]](http://i113.photobucket.com/albums/n203/chulo2006/91%20bronco/SIMG0037.jpg)
saginaw swap
01-19-2010, 11:54 PM
can you clock your pump over in the bracket any ? probably not.
01-31-2010, 03:57 AM
bone collector Wrote:what is saginaw?power steering pump.
02-01-2010, 11:59 AM
The GM/Saginaw "canned ham" pump is a tough pump. It also make more pressure than the Thompson pumps Ford used in most applications. If you look hard enough, especially at heavy duty trucks, vans, or large cars with hydroboost brakes, you will find Ford used these pumps too.
02-07-2010, 10:10 AM
bone collector Wrote:whats the differance in it and a factory bronco pump? alot. when i put the 37s on my bronco the ford pump lasted about a week.. switched to the sag pump, havent had a mins prob since...:rebel:
http://www.wheelindixie.com http://www.coastalcarolinaoffroad.com |
Need input on my NV4500 swap!! | knoxville714 | 12 | 6,321 |
06-20-2016, 09:59 PM Last Post: blazinchuck |
Manual to Auto swap and Auto to manual swap | wepuckett | 1 | 1,804 |
07-24-2014, 03:26 PM Last Post: wepuckett |
Brake problems after the 5.0 swap. | BucknEB | 10 | 3,044 |
10-29-2012, 03:07 PM Last Post: BucknEB |
AOD SWAP TO A C6 | markharrell | 3 | 1,931 |
09-30-2011, 09:18 AM Last Post: jollygrngiant |
BII 302 Swap | BroncJr | 27 | 12,986 |
04-27-2009, 11:39 PM Last Post: Mtrhd0024 |
Question on 87' Tailgate swap. | cavscout | 1 | 2,675 |
04-12-2009, 10:41 AM Last Post: sparkchaser |
Motor Swap Question?? | BigBird13 | 5 | 1,945 |
10-16-2008, 07:36 PM Last Post: BigBird13 |
SOLID AXLE SWAP | BroncJr | 7 | 7,005 |
09-14-2007, 05:24 PM Last Post: krazybronco |
