Manual to Auto swap and Auto to manual swap
Ok I am working on a deal with a guy that is doing a Auto to manual swap and I will be putting in the Auto. I have looked at the wild horses link for Auto to manual swap and the one thing that I wasn't sure about adapters and such wise was the trans to transfer case as they do a good job of showing you everything you need from engine to trans and linkage.
I have a manual trans sitting on my workbench and was wonder how to or if I need to pull the manual input shaft out of it for this deal. What other parts will he need.
Also what parts will I need to ask for.
Could use some help with a checklist on this if you all could. Thanks
  Need input on my NV4500 swap!! knoxville714 12 9,660 06-20-2016, 09:59 PM
  Manual brake push rod??? chuzie 13 8,612 01-06-2014, 03:04 PM
  Brake problems after the 5.0 swap. BucknEB 10 5,602 10-29-2012, 03:07 PM
  AOD SWAP TO A C6 markharrell 3 3,216 09-30-2011, 09:18 AM
  Carburetor and intake manifold 1974-302-auto jrshepherd 6 5,184 03-04-2010, 02:08 PM
  saginaw swap chulo2004 6 7,143 02-07-2010, 10:10 AM
Last Post: DeTowman
  BII 302 Swap BroncJr 27 19,610 04-27-2009, 11:39 PM
Last Post: Mtrhd0024
  Question on 87' Tailgate swap. cavscout 1 3,553 04-12-2009, 10:41 AM
Last Post: sparkchaser
  Motor Swap Question?? BigBird13 5 3,555 10-16-2008, 07:36 PM
Last Post: BigBird13
  ***C4 auto not shifting---need ideas ASAP*** chuzie 2 4,048 06-12-2008, 02:12 PM
