SOLID AXLE SWAP
Just wondering if the guys that have done the sas swap think about using d44's (front and rear) out from under 05 wrangler rubicon would work on a 90 bII.
check them out...
http://cgi.ebay.com/ebaymotors/ws/eBayIS...53041&rd=1
YOU CAN MAKE ABOUT ANYTHING WORK WITH THE RIGHT KNOWLEDGE, SKILL & EQUIPMENT I USED A DANA 44 FRONT & FORD 9" REAR FROM A '79 FULL SIZE BRONCO ON MY B2 AND I HAVE LESS THAN HALF OF THE BID PRICE IN IT, BUT I ALSO OWN A MACHINE SHOP WITH MILLS, LATHES, SAWS ETC AND THE BENEFIT OF 30+ YEARS METAL WORKING EXPERIENCE SO I EITHER FABED OR CUT AND MOVED WHAT NEEDED TO BE DONE. BUT IT CAN BE DONE!
RONNIE
'85 Bronco II 7" lift
BW1350 doubled 85:1 final crawl
Hydro-assist steering
Dana 44 front lincoln locked
Ford 9" rear trac-loc
Mile Marker 8000# winch
http://www.gulchesorvpark.com
the width i think would be perfect for the b2 alot of guys run d30s out of xjs and plus if you get these they are geared and locked but the rear would be kinda hard but you could cut off the coils stuff and put leaf spring perches on it
Not a bad deal,like Ben said/gears- lockers-4wheel disc. sweet set up!Chuck
I'd go for that!! The gears and air lockers alone will run you that price.
Brian
You guys keep talking, I'm getting ideas for my '88 project-when I hit the lottery!!! :lol: :lol:
ok i was just thinking about this today but i think the d44 that came in rubicons were elockers not air lockers so check out these axles before you get them and the rear was a limited slip
let me check on some jeep sites and come back to you
never mind found out they are air lockers but did find out the new jk's are e lockers
  Need input on my NV4500 swap!! knoxville714 12 9,679 06-20-2016, 09:59 PM
  Manual to Auto swap and Auto to manual swap wepuckett 1 2,910 07-24-2014, 03:26 PM
  Axle Tube Vents Casey835 4 3,578 03-01-2013, 08:20 PM
Last Post: Casey835
  ***9" Axle Gurus...Ring gear dug into pilot housing!** chuzie 7 5,089 12-05-2012, 12:35 AM
  Brake problems after the 5.0 swap. BucknEB 10 5,610 10-29-2012, 03:07 PM
  Axle / Gear gurus help!! SC74 4 4,128 03-28-2012, 08:52 AM
  F150 axle shaft tech blazinchuck 12 6,665 12-03-2011, 09:34 PM
  AOD SWAP TO A C6 markharrell 3 3,227 09-30-2011, 09:18 AM
  Stuck rear axle? (9") Action 6 4,543 06-24-2011, 09:42 PM
  rear axle shims? berg bronco 15 6,099 01-04-2011, 09:52 PM
