Need help with transfer case install
SC74 Wrote:what body support? Is it the rib under the tunnel?
Yep, that's right
[Image: Picture1.jpg]
I figure the 2" body lift will provide the clearance I need.
how about loosening the motor mounts to allow the tranny to angle down? You should not have to do this but the other option would be to loosen the front 6 body mounts and use a jack to raise the body enough to get the angle you want for the install.
When you removed the case was it difficult to separate and remove? was there a loud pop when it finally came off as though body pressure were being relieve that was resting on top of the case?
i cant really tell from the pics but i wonder if there are rub or wear marks on the body and the top of the case would have possibly met? this whole deal with the body being in the way is just weird.
I find it easier to leave the extension housing bolted to the transmission. It makes lining up the splines easier, but removing/installing the top bolts can be a PIA. The 2" of body lift will make the whole job easier. I also cut the top of my tunnel out and made a removable cover. This allows easy access to all the top bolts and linkages, and then I can use my cherry picker through the passenger door to lift and hold the transmission and transfer case when installing and removing.
chuzie Wrote:how about loosening the motor mounts to allow the tranny to angle down?
Yeah Chuzie, this is an option that we talked about today. We pulled it off attached to the transmission, which in hind sight is probably the way we should have tried for the reinstall. Since I need the 2" lift to close my hood :hysterical:, I figure I might as well move forward with that and then try it again. Project Snowball rolls on :toothy12:
if i were closer and had more time , i'd come help you.
I have the 2" lift installed so I'm tackling the case install again tonight.
:duel:
good luck, and lets us know how it goes!
Case installed! :chili: :rockon: :party:
Congrats! I'm sure that's a big weight off your shoulders you've been wanting to tackle.
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 2,723 09-19-2018, 02:50 PM
  Adjusting Transfer Case Shifter jdowns67 1 896 10-27-2014, 01:49 PM
  t-shift t-case won't go into 4-lo scbronco 3 2,526 04-01-2014, 09:54 AM
  what transfer case Ron Burgandy 4 1,978 08-18-2013, 11:06 AM
Last Post: 1st Bronco
  Southern Rods AC kit install..part 1-heater blazinchuck 22 7,670 03-09-2013, 09:47 PM
  ebay radiator(5.0 conversion) install... blazinchuck 8 5,683 10-15-2012, 10:30 PM
  Rattling/clicking noise from Transfer case jdowns67 3 1,426 05-15-2012, 08:03 AM
  bushing install ? firefighter2134 2 2,895 08-11-2011, 10:30 PM
  Oil Pressure Guage install location??? Crawdad 3 2,196 04-12-2011, 12:35 PM
  90 Transfer Case Queston 2000F150SAS 0 2,181 03-28-2011, 10:17 AM
Last Post: 2000F150SAS
