5.0 backfires - problem solved!
I piddled on this some yesterday and figured out that the trouble starts as soon as the temp hits 150* - not even hot, warm at best. It has plenty of power before it reaches 150* (which isn't long) - I dug a hole in the yard when I pulled up the the mulch pile - no hesitation and no backfiring. As soon as it hits 150* it starts puttering - can't even touch the throttle without it backfiring and most likely cutting off. I tried to limp it back to the concrete going 10-15 ft at a time and it stalling.
After getting it back on the concrete I let it sit and would key-on every once in a while to see the temp reading. I tried several times while it was 150* or just over and it just stuttered and backfired. I let it get down to about 130* and it ran perfect until the temp got back to 150.
I'm thinking it has to be a sensor from when it changes from "cold choke" mode to normal operating temperature mode.
Ok this might sound crazy but have had this happen to me on a 5.0 Mustang after putting new fuel injectors and intake and blah blah blah :xyxthumbs:
So if the fuel lines get hot (leaning against something) the fuel (gas) will boil and cause "air" pockets and cause backfires and rough idle ect.
On the Bronco (non FI) I covered all fuel lines that came in close contact to hot surfaces.
Does not seem like I can explain myself right this morning ... my retardness is really acting up this AM Confusedcratchhe:
that makes perfect sense JP... I even cracked my fuel cell to make sure the vent wasn't clogged. I do have some SS fuel lines running close to the pass side headers. I will pull them up and out of the way to see if it does anything different.
While splitting some firewood to burn tonight I decided to let the bronco idle up and get warm to see if moving the fuel lines away from the header would help.
It does seem to help - I moved both the supply and return up and away from the header and let the motor idle up to 180*. It did backfire on me SOME when I idled it up - even did a small power brake in rev. and forward. It's not 100% cured, but I think I'm on the right track with the fuel lines. No where else do they get near the exhaust, but I noticed something else....
While it was idling I held the supply line (flexible SS line) and you can feel the fuel in it. I noticed it was not a continuous supply - it would have a pause in it - then pressure for maybe 10 sec and then pause for 1 or 2 sec. Is this normal? Maybe I have a fuel pump issue???
I used to run an adjustable external fuel pressure gauge. That would give you the answer on that and the ability to adjust your pressure if needed. Not expensive an a good gauge to have.
If fuel supply is sporadic, that is not right. If you have a fuel pressure gauge, hook it up to the fuel rail fitting (it is a shrader valve like a valve stem for tires). Your fuel pressure should be about 40lbs and should not vary sporadically.
he may not have the shrader valve...i had to lose mine when plumbing my system. i recently got one from lkq that will work. took a while to find a fuel rail with reg,fuel ports,etc all on the pass side. i just need to install it
how did that happen? curious. on my 2 projects I was able to keep them (1 with HO mustang rails and 1 with Explorer rails).
Chuck is right - I don't have the shrader valve. I have a SS line that hooks up to the fuel rail at the weird ford fitting. I have considered putting an in-line permanent fuel pressure gauge in but didn't think it would be a "need-to" basis.
JP - you were carb right? I've seen that done on carbs but not efi.
SC74 Wrote:Chuck is right - I don't have the shrader valve. I have a SS line that hooks up to the fuel rail at the weird ford fitting. I have considered putting an in-line permanent fuel pressure gauge in but didn't think it would be a "need-to" basis.
Robert my Bronco was carb yes ... But in my younger days I played with fox body mustangs from the late 80's that's when I would run that gauge in line to make sure things were ok with my fuel after installing bigger injectors TB's ect
  Sticky Throttle Problem SC74 18 3,617 02-09-2012, 05:41 PM
  Battery Problem???? Start slow..... Help... Mill Knob 22 4,635 10-01-2009, 01:03 PM
  Need advice on tube flaring problem... chuzie 8 1,983 08-28-2009, 05:42 PM
Last Post: 66stocker
  93 Full Size Electrical Problem BigBird13 0 1,557 07-18-2009, 01:51 PM
Last Post: BigBird13
  problem with my 79 fordfan 4 2,864 01-04-2009, 10:04 PM
  electrical problem berg bronco 10 3,781 11-17-2008, 08:41 PM
  Headlight problem fomoco 8 2,240 03-31-2008, 11:49 AM
