DWB Build Thread
Got the 74 EB in January,
Added 2 1/2 " JBG springs thanks to Dixieboy at the M&G, just what the doctor ordered. Then installed add a leaf for now to level it.
Installed new extended brake lines and 76 F250 Mstr cyl to get the Disk fronts to work. Cleaned and undercoated underside and frame. installed new gas lines and filters. Last Friday night snatched out the front-end and installed new C-bushing, radius arm bushings. New shocks. Ordered extended track bar should be here in a day or two. Also found 302 power plant to stab soon. It'll need timing chain & gears, oil pump and pick-up tube and new pan. Removed cleana nd re-wrapped the wiring fornt to back. Dropped tamka and install new float and pick-up. Oh yeah cleaned , chacked and repacked hubs.
Got some greasy jeans and shirts, but aint this fun...
DirtyWhiteBoy
Pictures please
Sorry didnt have a Rachet-cam, But will take some shots to show before and after stuff. Got the adjustable Trac-bar installed this evening so I finally got to test drive. Oh Yeah happy with the suspension now it has some ballz. And a better stance.
I'll put some out soon. DWB
Ok today installed front extended brake line and started on Roller motor, I will try to add some pic's.
And a pictue of my old 67 and 78
Okay parts ordered for engine, new Timing chain and gears and oil pump..Tired of watching the oil pressure drop in tired engine, newly purchased 302 soon to be installed. Got a good deal on 302 it's very clean and has roller rockers bought from guy who has a collection of toys. Said motor was great and everything looks that way. It as 68 model block with 289 heads and Mallory electronics in distributor, came complete but figured a few new items cant hurt.
Last night removed pan and oil pump, installed new pump. Timing chain and gears. Even took a pic or two. will have to use pickup and pan from original engine once cleaned and painted. It's one step closer.
DWB
Another afternoon of wrenchin, Ready to pull tired engine, everythin unhooked just got to slide it out. Header bolts are a pain in the butt...No clearance for a socket on passenger side of engine. Pic's posted tomorrow. DWB
Well had to order Flex-plate teeth worn down to bad It'll be in Thursday..But here are pic's ready to pull tomorrow evening -hopefully
looking good.
Another evening worth of work, Got a lot of cleaning in the engine compartment. But the good news is out with the old; getting ready for the new one...primed Oil pump and installed rear sump pickup tube. I hate torgue converters (they are a pain) DWB
Oh Yeah...this things gettin close...Still gotta clean enigne bay...Stock Radiator didnt look to bad either. have to clean it up. got to get new hanger for it.
Oops hung dip stick on header bent the drap out of it. I think its time for a flexable tube.
Late night but with the son in laws help got the new power plant installed and bolted down. Now gotta hook everything back up and get it fired.....Getting it hooked up and soon ready to roll
  ECORS Class A race rig build broncosbybart 387 89,245 10-29-2014, 05:33 PM
  My 76 LUBR Build in SC Crawdad 177 40,185 05-14-2013, 07:13 PM
  Welch Racing Build thread cuz1 183 39,078 11-03-2012, 08:04 PM
  my bronco build 66bronco 65 18,748 04-17-2012, 11:54 PM
  My "built" thread nhopman 13 4,643 12-27-2011, 02:25 PM
  Bighorn Build Thread Bighorn 70 17,842 11-16-2011, 05:33 PM
  JohnPaul's Build johnpaulgolf 303 72,207 11-16-2011, 10:52 AM
  JayT's lil 66 build JayT 30 9,192 11-01-2011, 09:06 PM
