08-20-2012, 10:39 PM
Has anybody here ever done this to a stock colume? I have seen the grant discounts but they require a key not really wanting to do that.
Quick disconnect steering wheel
08-21-2012, 10:34 AM
No...But why?
08-21-2012, 01:18 PM
I used a stock column and a quick disconnect wheel. I had to weld the nut on the end of the shaft and I removed everything off of the shaft so it's essentially a naked shaft from the firewall up.
Here is a link to Classic where I posted some pics.
08-21-2012, 06:49 PM
chuzie Wrote:No...But why? To make it easier to get in and out. But I would like to keep the turn signals on the steering colume.
08-21-2012, 06:50 PM
SC74 Wrote:I used a stock column and a quick disconnect wheel. I had to weld the nut on the end of the shaft and I removed everything off of the shaft so it's essentially a naked shaft from the firewall up. Thats what I was thinking but keep the stock turn signals on it.
Heim Steering | wepuckett | 20 | 4,215 |
08-28-2015, 03:18 PM Last Post: wepuckett |
Steering box help | snipes243 | 24 | 12,036 |
07-17-2015, 09:42 AM Last Post: snipes243 |
What type Power Steering Cooler are you all using? | Broncitis | 7 | 1,884 |
07-16-2015, 01:32 AM Last Post: wepuckett |
Steering shaft Extension Question??? | Broncitis | 4 | 2,729 |
04-17-2015, 02:27 PM Last Post: Broncitis |
Power Steering issues | Crawdad | 31 | 5,043 |
07-28-2011, 09:29 PM Last Post: Crawdad |
Home made heavy duty steering | Timstrk | 4 | 2,685 |
11-25-2010, 10:47 AM Last Post: firefighter2134 |
power steering pumps | snipes243 | 9 | 4,762 |
11-15-2010, 05:17 PM Last Post: nhopman |
Wheel hop issues | JustJeff | 2 | 1,617 |
01-25-2010, 01:53 AM Last Post: JustJeff |
steering column | bluebooger | 0 | 1,404 |
01-19-2010, 11:57 PM Last Post: bluebooger |
HELP INSTALL POWER STEERING | PBONE2000 | 3 | 1,106 |
12-11-2009, 01:08 PM Last Post: blazinchuck |
