what transfer case
i have a 80 xlt bronco with a manual tcase. its the original and is leakin oil pretty bad. i need to know what case this is so i can get the kit to reseal it. it has no tag on it.
Is that a tank?....NO...its worse....Its my Bronco
Should be an NP208. This link has info and pics to compare with as well.
http://www.blueovaltrucks.com/tech/transfer_cases.htm
Is there another work day scheduled?
Yep. We will likely do the sept/oct days. I'll post about it as we get closer. Hope you can join us!
I must have done something wrong for my question to land on this crank case thread, thought I was posting on thread with the pictures from last work day.
VIN# makes it a 1985, the engine block# is an 1989, and the front end is from a 1987. I call it Broncenstein. [Image: bronco.gif]
  Adjusting Transfer Case Shifter jdowns67 1 754 10-27-2014, 01:49 PM
  t-shift t-case won't go into 4-lo scbronco 3 2,284 04-01-2014, 09:54 AM
  Rattling/clicking noise from Transfer case jdowns67 3 1,189 05-15-2012, 08:03 AM
  90 Transfer Case Queston 2000F150SAS 0 2,026 03-28-2011, 10:17 AM
Last Post: 2000F150SAS
  STak 4x4 Monster Transfer Case josephitguy 2 993 01-20-2011, 12:41 PM
  Need help with transfer case install 73Bronc 34 9,176 08-18-2010, 11:45 PM
Last Post: 73Bronc
  Ford Automatic Transfer Case Wiring 2000F150SAS 0 936 09-01-2009, 07:57 AM
  Transfer Case Issues Pup 2 2,421 08-28-2009, 06:59 PM
Last Post: Pup
  90 Transfer Case Motor Question 2000F150SAS 0 817 08-03-2009, 01:05 PM
  Transmission and Transfer Cases in Ford Fullsize trucks... Mtrhd0024 8 1,972 05-11-2009, 10:38 PM
Last Post: bone collector
