Need help at URE on our trail!
When you all pick a date I will more than likely come help. In this summer heat I will not be alot of help but will do what I can.
July is better for me, I'm busy the next 2 weekends.
Nick
I'll help come September
We will plan for July then. Work days available would be 11, 18, and 25th. The official work day would be the 18th. Thoughts?? I should be available any of those days.
I might be able to make the 18th......
Sounds good. Anyone else?
If you all are up for it, we can hang out at the shanty on Badin lake afterwards. I'm on the other side of the lake. It is about a 30 min ride from URE. Probably no more than a few miles away but there is no bridge from there to here! We have a couple of jet skis, a lake, and a grill. You might even get to see Chuzie flying overhead!
There is an air nat'l guard airport nearby. A few weeks ago we had a big 4 engine prop plane buzzing circles around it. Not sure if they were practicing taking off and landing or what but the plane was only a couple hundred feet off the ground. Very impressive beast!
Sounds good to me
broncosbybart Wrote:Sounds good. Anyone else?
It is now July. If you plan to come out on the 18th, please post up so we can get a head count! Bring a friend or three!
I think I can make it. That's a regular workday, correct?
Nick
I will likely be there. May be able to bring someone with me.
  URE workday Sat March 25 broncosbybart 17 6,289 05-22-2018, 09:39 PM
  Sat Feb 25 URE Workday broncosbybart 4 2,246 02-26-2017, 01:57 PM
  January 2017 URE Workday broncosbybart 6 2,721 02-16-2017, 01:47 AM
  Roll call- Oct 22 URE workday broncosbybart 15 5,514 10-23-2016, 12:13 PM
  URE Work Day - July 16 2016 nhopman 16 5,065 07-18-2016, 10:03 PM
  URE work day- Sat May 21, 2016 broncosbybart 17 4,852 05-21-2016, 09:40 AM
  URE March 19-20, 2016 Work Day nhopman 45 12,418 04-02-2016, 07:20 PM
  Feb 20 URE winter workday broncosbybart 39 11,144 02-24-2016, 10:16 PM
Last Post: mrwarner44
  URE Winter Workday Jan 23 broncosbybart 34 8,856 01-31-2016, 02:02 PM
  Dec 12 2015- URE trail run and Rendezvous Meeting broncosbybart 22 7,301 12-16-2015, 02:34 PM
