#81
I was just about to purchase the kit from BC and then I saw the 20 $ shipping and backed out. The kit is reasonably priced at under 37.00. I refuse to pay that hi of shipping. What is wrong with a if it fits it ships box from the USPS? Reckon I am back to fabbing my own.
The biggest thing you'll be up against in making your own kit is the DOM tube used for the sleeves. If you can source something for that, you're good to go
broncosbybart Wrote:The biggest thing you'll be up against in making your own kit is the DOM tube used for the sleeves. If you can source something for that, you're good to go
[Image: aea790a9eeabd654dbecd18a32e95047.jpg]My frame seems to be in good shape where the box attachs to it. I am going to do some measuring and drill a plate to strengthen it inboard and outboard. It does look like it had been loose and wore some around the bolts.
Careful putting a plate between the box and the frame it will change your drag link length.
The biggie is making some reinforcement tubes on between the frame. Easily done but easily forgotten
[Image: b5877a839a251fdab80007129e9d6afe.jpg] The Outer plate is fabbed using a piece of 3x5 rectangular tubing disected and drilled for my purposes. The stock supports inside the frame look good. I am running 33 inch tires and after I do this reinforcement I think it will be stout enough for 33 or 35 inch tires. If not I can always do it again.[Image: bdeec1ea1af19f977eb70dfda8cf5c0f.jpg]
OK I give up. Has anyone found a alternative to WEst Texas for rebuilding the Steering Sector?
Clay should know considering his recent experience.
Anyone know which year F 150 4x4x2 box to use to do that conversion.
http://www.wcb4x4.com/tech/diyrockcrawler.shtml
  Lil Red Riding Hood Build Broncitis 11 7,356 03-04-2016, 12:14 AM
  Manual brake push rod??? chuzie 13 5,067 01-06-2014, 03:04 PM
  Irmo73's Build Irmo73 159 28,511 03-09-2012, 01:13 PM
Last Post: Irmo73
  92 Fullsize Build - Scotts Bronco nitro 44 10,309 01-12-2012, 08:45 AM
Last Post: nitro
  Please educate me on 3 speed trans RAT & RAN? Mill Knob 11 6,601 01-11-2011, 10:34 PM
Last Post: Mill Knob
  Stock 66 interior rebuild thread 66stocker 37 12,500 04-03-2010, 11:07 AM
Last Post: 66stocker
  Need Tie-Rod Reamer 2000F150SAS 0 1,767 10-20-2009, 08:33 AM
Last Post: 2000F150SAS
  miscellaneous ford tech thread... blazinchuck 0 2,625 02-17-2009, 11:02 AM
  70 early bronco (mild build up) broncomania 8 2,429 12-09-2008, 11:56 PM
  My new horse: 1991 Bronco trail build. manny 5 5,081 09-11-2008, 12:54 PM
Last Post: manny
