Please educate me on 3 speed trans RAT & RAN?
I know the differents in RAT & RAT 3 speed trans is their adapter housing.
My Bronco is in need of a new clutch and flywheel. I bought a 3 speed RAT trans a year ago that seems to be better then the 3 speed that is in my bronco now.
The tansmisson in my Bronco is not the original 3 speed, because the Original locked up on the PO and he just slap an old 3 speed transmisson in it and kept driving it. The 3 speed that is in my bronco now is a RAN. Would any body know what 3 speed trans was suppose to come in my 1969 Bronco?
One thing that I did notice was the RAN transin my bronco has a drain plug in the bottom and the RAT don't. :popc1:
sorry George, but i have no experience with 3 speeds at all. they all been C4 or 4 speeds. good luck man,Chuck
Pretty sure it's supposed to be a RAT that year. Mine's a 71 and its a RAT
jdowns67 Wrote:Pretty sure it's supposed to be a RAT that year. Mine's a 71 and its a RAT
Found out by a Chart on the internet that my bronco has in it a 3 speed from a 1967-68 bronco that had 289. The 3 speed trans that I want to put in it can't find on the chart. So still looking.
Tks Jdown67 for the info. Question for you Jdown67 does your trans have a drain plug on the bottom? The Rat trans that I have does not. So how do you change the fluids in it?Confusedcratchhe:
side load panel?
I have a RAT (I think) here with a drain plug in it. I am getting ready to take it to the scrapper, unless you need it. It came from a 69. IIRC, the RAT has a lower first gear ratio than the later RAN. Not much lower, but just a little. Kinda like the ratio differences for low range between a T-shift and J-shift T-case.
I'll look about the drain plug when I get home today Mill Knob. I just looked and on broncograveyard site it shows the RAN as having a case length of 9-3/8" and the RAT with a case length of 9-3/4". I never noticed this before.
broncosbybart Wrote:I have a RAT (I think) here with a drain plug in it. I am getting ready to take it to the scrapper, unless you need it. It came from a 69. IIRC, the RAT has a lower first gear ratio than the later RAN. Not much lower, but just a little. Kinda like the ratio differences for low range between a T-shift and J-shift T-case.
I will take it off your hand... Pm me your number so I can talk to you about when I am coming down that way....
Thanks again.
jdowns67 Wrote:I'll look about the drain plug when I get home today Mill Knob. I just looked and on broncograveyard site it shows the RAN as having a case length of 9-3/8" and the RAT with a case length of 9-3/4". I never noticed this before.
The info is in the Toms cataloge. Let me know what ya find on that drain plug.
I know a guy that is restoring a 1969 ford bronco. So I call him up and went over and look at the trans and it has a RAT in it. So that means I am going to place a RAT trans in mine.
  Broncitis Rat Rod build thread. Broncitis 121 57,273 04-01-2016, 10:53 PM
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 6,088 05-15-2014, 11:50 AM
Last Post: rbodine
  cummins to a ford small block standard trans adapter plate Rdnckdemo 2 2,506 04-14-2013, 01:19 AM
Last Post: Rdnckdemo
  C4 Trans Dipstick Tube SC74 5 4,919 10-24-2011, 01:35 PM
  Help identifying trans jdowns67 1 1,971 01-22-2011, 11:41 PM
  c4 trans filter change spring and thing! jrshepherd 2 3,639 03-13-2010, 08:12 PM
  C4 Trans. Cooler Fittings jrshepherd 14 7,695 09-22-2009, 05:44 PM
  Question: Trans lines and Gas tank jrshepherd 0 2,439 08-24-2009, 10:22 PM
  Trans. Idea BigBird13 2 3,658 10-24-2008, 05:00 PM
Last Post: BigBird13
