Off Road!
#41
justin Wrote:If I were you, I'd take a day before you get the lift and grind out the rivets now. Even if you decide against the lift later, it makes it much easier to change your radius arm bushings. I can't remember on your year model, but I think only the driver side is riveted on. The passenger sides on the later models came bolted from the factory because the bushing was prone to failing quickly due to the close proximity to the catalytic converter.
I used a grinder to get the head off and then used a punch to drive them out. I've also heard of people doing it much quicker with a torch or an air chisel.
After that it is a matter of unbolting the TTB, and installing all the new brackets, coils, brake lines, etc. Make sure to get a nice pitman arm remover and it helps to have a buddy around to wrestle the TTB halves back into place once the new brackets are in.
I will keep all of that in mind. I will make sure I have at least one other person helping me with this. Really wouldn't want to screw this up. Smile
Wtih that in mind, does SC have inspections? 2 of my cars are licensed in FL but the Pilot is SC registered. Not that I have done anything to it but just wondering in case I tag my Bronco for SC one day. I am sure it is not grandfathered in right?
chuzie Wrote:Wtih that in mind, does SC have inspections? 2 of my cars are licensed in FL but the Pilot is SC registered. Not that I have done anything to it but just wondering in case I tag my Bronco for SC one day. I am sure it is not grandfathered in right?
I don't know about SC and actually now that I think about it. I think that the bronco is Grandfathered in because I didn't have to pay for the emmissions test when I had it inspected. So I guess I could just rip it out. Smile
Nope, no inspections at all here in SC.
justin Wrote:Nope, no inspections at all here in SC.
Thats another reason why I love SC!
Ya, no inspections....YET.
We used to have them but we were so good and law abiding, the officals decided it was a wate of time.lol
That must be nice. Smile I am pretty sure ours is exempt. I really should find out.
No inspections required in NC if your vehicle is 35 yrs or older.
bucketobolts Wrote:No inspections required in NC if your vehicle is 35 yrs or older.
What year is the emmissions test cutoff? I thought it was 93 or something like that.
  Took the 4door for a little road trip Bronco Biff 5 1,135 11-28-2013, 09:23 AM
  new off-road recovery vehicle DeTowman 26 5,286 10-26-2007, 10:28 PM
Last Post: DeTowman
