01-07-2009, 03:55 PM
I just picked up a 1976 F100 Dana 44 front rear and it has drum brakes, how hard is it to swap to disk brakes? Cost for this +/-?
Thanks, John
Thanks, John
1976 F100 Dana 44 Question
Thanks, John
01-07-2009, 06:03 PM
You can do the popular "Chevy" conversion really cheap.
http://classicbroncos.com/disc.shtml Or you can swap the knuckles out from a '77-79 Ford D44. You will probably also want to upgrade to the F250 "camper special" master cylinder. It makes you work a little less when running big tires.
01-07-2009, 06:08 PM
This rear will be going into a 2000 F150.
So i have to swap the whole knuckle to run disc brakes (just the knuckle)? I guess the caliber bracket is on the knuckle? Thanks, John
01-07-2009, 06:30 PM
If you use the '77-79 Ford knuckles, I believe the brackets are cast on the knuckle. Then you need the spindle that the rotor/hub rides on and holds the axle in. And of coarse the rotor/hub, caliper, and hoses.
01-07-2009, 11:31 PM
u should have bought mine it already had disc brakes!1
upergrin::rebel:
http://www.wheelindixie.com http://www.coastalcarolinaoffroad.com |
| Steering shaft Extension Question??? | Broncitis | 4 | 4,658 |
04-17-2015, 02:27 PM Last Post: Broncitis |
| Exhaust question | Casey835 | 27 | 14,954 |
08-16-2013, 06:03 PM Last Post: blazinchuck |
| dana 44 mods | 64500xl | 8 | 4,047 |
07-06-2012, 08:44 PM Last Post: chuzie |
| 1991 351W EFI Question | Crawdad | 4 | 3,885 |
03-27-2012, 09:05 AM Last Post: broncosbybart |
| Hard top Question | 744x4 | 5 | 6,169 |
09-06-2011, 10:32 PM Last Post: Mill Knob |
| Tire question | dixieboyz13 | 12 | 7,820 |
08-25-2011, 01:58 PM Last Post: ncsubronc |
| Fiberglass Dr Insert Question | 744x4 | 5 | 3,698 |
08-10-2011, 01:24 PM Last Post: dixieboyz13 |
| 9" pinion question | scbronco | 10 | 6,063 |
01-07-2011, 08:23 PM Last Post: Crawdad |
| TTB lift question | jdowns67 | 7 | 4,726 |
11-20-2010, 09:36 PM Last Post: broncomatt |
| v8 water pump question | jrshepherd | 7 | 3,996 |
11-08-2010, 10:18 AM Last Post: broncosbybart |
