Dumb question alert.
how do you tell the difference between a 302 and 289 block thanks.
As far as I know the blocks are the same. The only difference between the two was the stroke length. It should have a casting number under the intake as to which it was from the factory. You can make a 289 a 302 by changing the crank and vice versa. You can also make either a 347 by doing the same thing plus .030" over, I think.
Tim
[Image: 2rwp56f.png]
thanks
Okay so I looked all over the block and all I could find were these numbers
DI0-8015-AA. On the heads were the numbers 351. Any help? Thanks
The casting on the block designates it as a 302 block. Most all the 289's were C6-C5 and prior castings. The 302 began with the C8 casting and progressed.
so its a 302 block with 351 heads?
Probably. Just means its been rebuilt once already. I ran that combination on a previous engine.
Tim
thanks. Tim
  Steering shaft Extension Question??? Broncitis 4 4,692 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 15,182 08-16-2013, 06:03 PM
  1991 351W EFI Question Crawdad 4 3,935 03-27-2012, 09:05 AM
  Hard top Question 744x4 5 6,212 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,902 08-25-2011, 01:58 PM
Last Post: ncsubronc
  Fiberglass Dr Insert Question 744x4 5 3,750 08-10-2011, 01:24 PM
Last Post: dixieboyz13
  9" pinion question scbronco 10 6,135 01-07-2011, 08:23 PM
  TTB lift question jdowns67 7 4,800 11-20-2010, 09:36 PM
  v8 water pump question jrshepherd 7 4,063 11-08-2010, 10:18 AM
  90 Bronco TTB Yoke Question 2000F150SAS 2 3,078 02-16-2010, 10:07 PM
