1990 Bronco Front Locking Hub Question
We just replace out automatic hubs with locking hubs and the one hub seam a little loose, all the bolts are tight but it has a little wiggle in it. Is this ok or do i need to shim somthing?Confusedcratchhe:
Thanks, JOhn
All thrush washers installed in right place? Bearing pre-load the same? Weak spring? Could be a lot of things!! :xyxthumbs:
Not really sure about washer or springs. We got the truck back from East Coast Gear last month after installing gears and they replaced the hub to manual hub for us. When i say movement I mean a LITTLE movement. Is a little movement bad???
Thanks
F1504x2 Wrote:Not really sure about washer or springs. We got the truck back from East Coast Gear last month after installing gears and they replaced the hub to manual hub for us. When i say movement I mean a LITTLE movement. Is a little movement bad???
Thanks
Mine doesn't move or wiggle at all. I'm not sure if "a little" is ok. Someone will tell you just be patient. :xyxthumbs:
there shouldnt be any play in a locking hub cuz it will let water in and mud or it can cuz it to fail on u while on the trails is it just one side
GO BIG OR GO HOME!!!
Just one side and it's a only a small wiggle, i have pulled it off it still clean and dry and it's been like this for the past 4-6 weeks.Confusedcratchhe:
I don't like the sounds of that... It's normally just the opposite.. you have to push the outer axle out to get the locknut on all the way... I'd definitely give chase (ECGS) a call... if it's wrong, he'll make it right!
definetly take it back, if there is play in there it indicates a loose component. Posibly an incorrect spring or a missing part. Water will certanly get in there if you wheel like that.
New hubs should be super tight, some times they even feel to tight.
I would give them a call.
Any one have an exploded view of all item in the hub so i can check to make sure nothing is missing?
Thanks
F1504x2 Wrote:Any one have an exploded view of all item in the hub so i can check to make sure nothing is missing?
Thanks
Let me dig one up, if I don't already have it.... I'll post it up later today.
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,536 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,943 05-22-2018, 09:38 PM
  Locking Hubs?? Whats the best??? Broncitis 9 10,348 02-26-2017, 01:51 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,094 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 5,136 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 7,023 01-31-2016, 03:55 PM
  Steering shaft Extension Question??? Broncitis 4 4,677 04-17-2015, 02:27 PM
  Front shock mounts snipes243 14 7,427 03-01-2015, 07:51 PM
  Another Bronco Floor Replacement jdowns67 83 32,909 12-20-2014, 11:33 AM
  Exhaust question Casey835 27 15,034 08-16-2013, 06:03 PM
