Front shock mounts
So I recently put in some f250 shock mounts on the bronco. Well today the shocks I ordered came in And my desire to fast got a little ahead of me. So my shocks are a bit to big. [Image: a8e2f41e5d8613d2ce4ba2b0810f6187.jpg] So now I need some new mounts. So what does everybody recommend.
Just grind the shock down a bit. It's close.
I have to say I disagree, if you grind on the shocks you will void any warranty the shocks have. These shocks are can be rebuilt and revalved if needed, if you grind them you would have to pay for that. What about spreading the mounts apart and using larger spacers on the bolt. Not sure how strong they would be if ground down to clear the mount.
As a last resort you can sell them to me, LOL.
Guess the sarcasm font wasn't bold enough Smile
That sucks on the mounts not working. I'd be tempted to modify the tops of the shock towers to make it work. Otherwise, time to cut them off and look at some type of shock hoop
Cant tell how they mount. Can they be flipped upside down?
Can you tweek the 250 mount?
Can't flip em upside down first off they wouldn't look as cool that way 😎 and second of all they change the valving. I'm pretty sure I just cut them off and do it right and use a shock hoop. Now the main questions what shock hoop do I use?
I have no experience with hoops other than duffs. Mine work well but I have nothing to compare them to.
I have looked at these
http://www.ebay.com/itm/231252102825
And
http://www.wcb4x4.com/mm5/merchant.mvc?S...y_Code=SSP
I like the ebay ones. The Duff's ones should work well too. Those WCB units are expensive!
I like the eBay set but am concerned he has so little feedback. I'd get more info from the guys on classic.
  Modifying Four Core Radiator Mounts Crawdad 3 3,016 07-30-2011, 12:17 AM
  Front D44 Ring/Pinion and upgrades scbronco 17 7,102 12-31-2010, 10:07 PM
  Used front hub jdowns67 2 2,091 10-31-2010, 11:06 AM
  Front Axle Olredneck 0 1,674 09-03-2009, 08:44 PM
Last Post: Olredneck
  Bronco Front Rear Question 2000F150SAS 8 4,157 05-28-2009, 02:22 AM
Last Post: supertoyota88
  1990 Bronco Front Locking Hub Question 2000F150SAS 16 9,779 05-21-2009, 04:29 PM
Last Post: 2000F150SAS
  1990 Front End Alignment Question 2000F150SAS 5 3,973 12-30-2008, 07:32 AM
  Fabbing New Rear Shock Mount Bighorn 5 4,897 11-19-2008, 07:01 PM
Last Post: Bighorn
  Locking down the front chuzie 21 8,945 10-29-2008, 08:07 PM
  Front disk/Rear window tapiot 2 3,173 08-23-2008, 08:49 PM
Last Post: tapiot
