Need Advice on 351W Headers
I'm looking to purchase some headers for my EB. I have a 351W with manual tranny, so space is limited. Post up if you have a recommendation on headers that work well for this setup. Thanks in advance :xyxthumbs:
I run Hedman's on my 351W. They could use a bit of tweaking to get the collect on the pass side off the frame rail and the tubes get a bit close to the inner fenders. If it is in your budget get the Jet-Hot coating. I got the Elite coating and it did not last a year.
Thanks for the advice. I called Jet-Hot this morning. They have Hedman's that are 1.5 to a 2.5 collector for $352. The Hedman part number is 89410. Does this match your setup?
If your real worried about space look into hooker headers. They are a fenderwell exiting header. I'm currently runing them on my 289. But will keep them when I swap in my 351 that's currently sitting in the shop. Also there was a guy on classic that was selling some real nice dyno tuned fenderwell header for a realy nice price. If I remeber right you could them coated and with duel flowmaster for like 400 something. I can find it if your intrested.
As for coatings check out calico coatings. They are local and have some awsome finishes for headers. They did a bunch of headers in this flat black finish for us at the race shop. And it holds up great no peel at all.
73Bronc Wrote:Thanks for the advice. I called Jet-Hot this morning. They have Hedman's that are 1.5 to a 2.5 collector for $352. The Hedman part number is 89410. Does this match your setup?
That is them. Just for comparison Summit list the Jet-Hot coated at $479.95. That is a great deal for $350. I believe I gave $300 for the Elite's.
Dang I just got a quote on a set of standard hedmans with sterling finish, and they said it would be 379.83, what finish are you looking at getting 73bronc .The elite's were 501.88 I can't swing that, but they do look nicer with the ball and socket, Also would the hedders interfere with a deep trans pan? sorry for the highjack
Felipe Wrote:Dang I just got a quote on a set of standard hedmans with sterling finish, and they said it would be 379.83, what finish are you looking at getting 73bronc .The elite's were 501.88 I can't swing that, but they do look nicer with the ball and socket, Also would the hedders interfere with a deep trans pan? sorry for the highjack
The quote I got was for the sterling finish
bucketobolts Wrote:That is them. Just for comparison Summit list the Jet-Hot coated at $479.95. That is a great deal for $350. I believe I gave $300 for the Elite's.
Thanks for confirming. Happy Birthday to me! Confusedupergrin:
Just wandering if you recieved your hedders yet? I ordered mine about 3 weeks ago and havn't seen them yet, they still haven't charged me for them either, I called the guy and he said all is well so I guess I'll wait a little longer and see,(Starting to get impatient)
Supposedly BC's will fit with a 351/manual combo. They have a fitment table if you scroll down. I think they're shortys, dunno if that matters. http://www.bcbroncos.com/exhaust08.html
  What to do advice Phoneman 5 5,586 05-14-2014, 05:56 PM
Last Post: Phoneman
  Headers jtoney51 7 4,977 07-02-2013, 11:28 PM
  headers and tires Ron Burgandy 5 3,782 09-18-2012, 01:54 PM
  1991 351W EFI Question Crawdad 4 3,885 03-27-2012, 09:05 AM
  Specs for 351W motor mount bolts? 73Bronc 11 6,063 09-27-2011, 11:36 PM
Last Post: 73Bronc
  A little advice rancej 5 3,632 03-19-2011, 11:53 PM
Last Post: rancej
  Cam advice.... chuzie 32 18,640 02-01-2011, 07:34 PM
  Headers - Shorty or Full Length 2000F150SAS 3 3,419 01-27-2010, 04:08 PM
  Thinking about swapping my 351W for a 302 cavscout 8 4,298 10-22-2009, 08:02 AM
