door lock question
went to get in my bronco today and the key wouldn't turn one bit...i couldn't even pull on the handle inside to get it to open..tried grabbing it with some needle nose and it wouldn't come up...any suggestions?..oh and they are power locks but there is a short on my side cuz i got it wet one day
Pull the lead off the door lock motor... Could be energized all-time do to that short you say you have...
Otherwise it's a seized linkage. Disconnect the linkage from the motor and you should be able to unlock with key and interior door handle.
thanks...will be trying that on tues on my day off given i am not hunting
  Steering shaft Extension Question??? Broncitis 4 4,657 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 14,952 08-16-2013, 06:03 PM
  1991 351W EFI Question Crawdad 4 3,884 03-27-2012, 09:05 AM
  Hard top Question 744x4 5 6,167 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,820 08-25-2011, 01:58 PM
Last Post: ncsubronc
  Fiberglass Dr Insert Question 744x4 5 3,697 08-10-2011, 01:24 PM
Last Post: dixieboyz13
  Removeable door frame Mod w/ Pics scbronco 8 4,446 04-20-2011, 03:50 PM
  9" pinion question scbronco 10 6,061 01-07-2011, 08:23 PM
  TTB lift question jdowns67 7 4,725 11-20-2010, 09:36 PM
  v8 water pump question jrshepherd 7 3,996 11-08-2010, 10:18 AM
