saginaw swap
[Image: SIMG0037.jpg]im working on my saginaw swap but ran into a problem. for some reason the line from the ac compressor sits right on top of the steering pump cap! the only way i can put the cap back on is if i force into place. looking at other forums about the swap mi noticed that their pumps were in the clear of that ac line. did i forget to do something? i got the set up from a 95 e-150 351. my bronco is a 91 w/ 351 as well. here is a picture of what im talking about. its not the actual pic of my bronco but its the same set up. when looking at the pic, you'll see the line comimng from the compressor. in my situation, that line sits right on top.
can you clock your pump over in the bracket any ? probably not.
what is saginaw?
Lifes a garden dig it
bone collector Wrote:what is saginaw?
power steering pump.
whats the differance in it and a factory bronco pump?
The GM/Saginaw "canned ham" pump is a tough pump. It also make more pressure than the Thompson pumps Ford used in most applications. If you look hard enough, especially at heavy duty trucks, vans, or large cars with hydroboost brakes, you will find Ford used these pumps too.
bone collector Wrote:whats the differance in it and a factory bronco pump?
alot. when i put the 37s on my bronco the ford pump lasted about a week..
switched to the sag pump, havent had a mins prob since...:rebel:
http://www.wheelindixie.com
  Need input on my NV4500 swap!! knoxville714 12 9,649 06-20-2016, 09:59 PM
  Manual to Auto swap and Auto to manual swap wepuckett 1 2,900 07-24-2014, 03:26 PM
  Brake problems after the 5.0 swap. BucknEB 10 5,582 10-29-2012, 03:07 PM
  AOD SWAP TO A C6 markharrell 3 3,213 09-30-2011, 09:18 AM
  BII 302 Swap BroncJr 27 19,579 04-27-2009, 11:39 PM
Last Post: Mtrhd0024
  Question on 87' Tailgate swap. cavscout 1 3,549 04-12-2009, 10:41 AM
Last Post: sparkchaser
  Motor Swap Question?? BigBird13 5 3,542 10-16-2008, 07:36 PM
Last Post: BigBird13
  SOLID AXLE SWAP BroncJr 7 9,332 09-14-2007, 05:24 PM
Last Post: krazybronco
