AOD or E40D - 90 Bronco
Do i have a AOD or E40D? I have a 90 Bronco with a 302 and the overdrive is located on the shifter selector with park, drive, etc. (NOT a push button on the end of the gear selector).
What do i have?
Thanks
Sounds like AOD to me. :xyxthumbs:
My 91 is 351 with E4OD and it has a push button overdrive on the dash.
here's a quick id looking at the bottom of the pan.
[Image: ford-pan-id.jpg]
AOD :rebel:
http://www.wheelindixie.com
Tahnks all!!:biggthumpup:
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,526 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,941 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,076 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 5,130 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 7,002 01-31-2016, 03:55 PM
  Another Bronco Floor Replacement jdowns67 83 32,814 12-20-2014, 11:33 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 4,488 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 4,457 05-19-2013, 08:43 PM
  Bronco Help Around Greenwood Jbass 29 20,181 01-20-2013, 03:16 PM
  Bronco techs in/near Raleigh? Mbowles 10 5,703 11-30-2012, 07:07 PM
Last Post: Mbowles
