Kick Down Tube C4
Hello. I have a 74 EB with a c4. I found a kick down tube in a box full of parts and tried to install. It seems like it's a little short. The lever looks to be pulled back to far and would only engaged if the truck was near full throttle. The bronco has a 2-3" body lift. Would that make a difference? Any suggestions. Thanks again for all of your help. Confusedcratchhe:
Do you have a 4V carb?
I'm not sure what you are describing but the kick down is only supposed to engage, push back, at near or full throttle. If is engages at less than that the tranny will downshift before it needs to, and just make the engine rev higher.
I have a motorcraft 2bbl. If it is supposed to engage near full throttel than I'm good. Thanks again for all the help!
Good, a 4V moves the linkage forward and the factory rod will need to be lengthened.
  Axle Tube Vents Casey835 4 3,537 03-01-2013, 08:20 PM
Last Post: Casey835
  C4 Trans Dipstick Tube SC74 5 4,883 10-24-2011, 01:35 PM
  C4 KICK DOWN CABLE LUKE/KANE7707 3 3,683 03-13-2011, 05:05 PM
Last Post: LUKE/KANE7707
  Kick Down Cable jrshepherd 2 4,290 01-31-2010, 12:34 AM
Last Post: 744x4
  Need advice on tube flaring problem... chuzie 8 3,903 08-28-2009, 05:42 PM
Last Post: 66stocker
  Leaky tranny dip stick tube. chuzie 4 2,822 08-10-2008, 09:16 PM
