04-07-2010, 12:34 AM
I'm looking on doing a conversion on my 77 Bronco and heard that the Explorer came with a V-8, auto and transfer case that can be put in my rig. Any help will be appreciated.
Dan
Dan
Engine and transmission replacement from a Explorer
Dan
04-07-2010, 01:11 AM
hit the tech thread and search "5.0 conversion" you should get alot of the basic info there. bodylift , fuel tank conversion(return line for the efi pressured li nes) etc. iirc the explorer 5.0's have the gt40 intakes.
also get as much with the donor as possible , wiring , fuel rails and injectors , computer etc.
I think my rust is rusting...
04-07-2010, 02:48 PM
the engine is a go but i am not sure about the transfer case. i seroiously doubt it. the engine is nice because of the extra clearance you get with the mechanical fan from the radiator and the PS pump setup too.
04-26-2010, 10:06 AM
The engine is good combo. Look for 96 Explorer, they have the three bar gt40 heads versus the gt40p heads. You will want to switch over to a mustang harness and computer to run the motor.
The tranny is a 4r70w. great transmission, but you will need a baumannater computer to run the tranny. http://www.becontrols.com/ The transfer case is a no go. You can adpat the 4r70w to the d20 with an AOD kit from AA or use a ford np205 or atlas as a direct bolt on. |
| Cradle for temporary engine storage | wormhole | 4 | 2,291 |
03-07-2013, 07:33 PM Last Post: Bronco Biff |
| Charleston, SC engine builders | ncsubronc | 4 | 3,157 |
06-28-2012, 12:32 PM Last Post: ncsubronc |
| NEED HELP (engine hoist) in Atlanta area. | BucknEB | 9 | 4,297 |
12-15-2011, 11:51 AM Last Post: BucknEB |
| Quick Transmission Fluid Question | 2000F150SAS | 1 | 2,014 |
08-06-2011, 03:49 PM Last Post: jrshepherd |
| Engine Swap...wanna help | UTfball68 | 4 | 3,608 |
09-17-2009, 07:57 PM Last Post: UTfball68 |
| C4 Transmission rebuild | Pup | 16 | 8,972 |
05-13-2009, 11:56 AM Last Post: broncomatt |
| Engine HELP!!!! | brewie212 | 9 | 4,024 |
12-15-2008, 10:05 AM Last Post: bucketobolts |
| Explorer Serp Conversion (PS Pump?) | chuzie | 1 | 1,864 |
04-06-2008, 03:30 PM Last Post: chuzie |
| New Engine for the 79! | DeTowman | 0 | 1,572 |
01-25-2008, 04:54 PM Last Post: DeTowman |
