Spark Plug wire installation
I think im brain dead. I have a 1996 5.8L Bronco. I have changed the plugs, cap and rotor. I now need to install new plugs. I read the firing order is 1-3-7-2-6-5-4-8. If I start at the number one position on the cap does number two position counter clockwise go to the third piston? Confusedcratchhe:
This is what I found for a 5.8L, but it does not match your firing order. I'm going to look some more to see if I find anybody else with your order.
Removed the old diagram.... Here is the correct one that matches your firing order.
[Image: 00000071.gif]
from....http://autorepair.about.com/library/firi...o-7237.htm
Thanks. That is what I was thinking, but was brain dead today. Thanks for the help!
  Receiver hitch installation 73Bronc 3 4,075 10-19-2011, 09:33 AM
Last Post: 73Bronc
  Do vacuum lines plug in here? Ogeechee 4x4 3 2,657 09-28-2011, 06:33 PM
Last Post: markharrell
  1996 5.8L spark plug wires and coil jrshepherd 0 1,810 02-08-2011, 06:16 PM
  Spark Plug gaps for a 351 Windsor Crawdad 5 6,763 01-04-2011, 04:57 PM
  Changing spark plugs 1996 5.8L jrshepherd 0 1,674 12-13-2010, 10:42 PM
  Tuffy Security Console Installation 73Bronc 5 6,739 09-29-2010, 03:04 PM
Last Post: 73Bronc
  Torque Spec. Spark Plugs- 1974 302 v8 jrshepherd 4 3,818 01-24-2010, 12:47 PM
